Thread: side light problems
  1. Question side light problems
    Hope someone can help as I am going mad here!
    I have an 2003 130TDI Passat saloon. When I switch on my headlights to the first setting (side lights) neither the front or rear lights on the driver side come on. The indicator, brake and fog light are however ok on the same side. The front dipped beam on the driver side is also ok as I think this is on a seperate circuit.
    To cut a long story short went to change a bulb in the rear (driver side) and when the unit holding all the bulbs was out I think it made contact with the "lashing eyes", the chrome bits used to tie in luggage. Any way I think this may have shorted the circuit as I heard a spark but cant find the fault. I have checked the fuses near the driver dash and these are OK as are the bulbs. Is there anything obvious I am missing out?
    scotland
    39 Post(s)
    There must be a fuse gone somewhere,try substituting the fuses with some new ones,it's not always possible to see if the fuse has gone or not.You can get a bag of different size fuses to suit all,not expensive,let us know if this sorts it out,cheers Calum
    Used an amp-meter and sure enough the fuses were gone. With the naked eye they looked as good as new! Thanks for the advice.
    Jun 2006
    UK, Mids
    There are also additional fuses above the foot pedals in relay/fuse holders, you have to remove the lower dash panel to get to them 3 or four torx screws and 2 clips at the top.
  1. Replacing drivers side brake light
    By sjchadwick in forum TT - 8N Forum - 1998 - 2006
    Last Post: 09-05-2007, 11:23 AM
  2. A4 2004 tdi - side light replacement
    By Moni453 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-04-2007, 03:49 PM
  3. a4 p/side door electrical problems
    By stubbsy in forum Audi A4 - Archive Topics
    Last Post: 25-02-2007, 02:04 AM
  4. Audi A4 Cabriolet Replacing Side Light Bulbs
    By nrahuf in forum Audi A4 - Archive Topics
    Last Post: 10-02-2007, 09:35 PM
  5. Light problems
    By howard13 in forum Passat - Archive Topics
    Last Post: 31-07-2006, 08:46 PM
