Thread: Temperature Light beeping
  1. Exclamation Temperature Light beeping
    Jun 2008
    Hi guys
    The temperature light on my 1999 Mk4 GTI has suddenly start to beep at me every time i start the car up, however this only lasts for a few minutes and then it stops. The temperature guage however doesnt go crazy and the car doesnt overheat.
    Looking at the level of coolant in the tank it looks slightly below the minimum. Is this what the problem is? I dont want to go messing with it if i don't know what the problem is
  2. Re: Temperature Light beeping
    Apr 2007
    N.Ireland
    Welcome to the forum.
    If I remember correctly, the light will illuminate yellow if the coolant level is too low and it will illuminate red if it is overheating. Which colour is it?
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  3. Re: Temperature Light beeping
    Jun 2008
    The light is red, however the car isnt overheating, when i first discovered it it was beeping at me for about 2 minutes and then it went off, i then drove nearly 100 miles and had no problems
  4. Re: Temperature Light beeping
    Feb 2007
    South West
    It sounds like a problem i had, when you start the car up a message comes up saying to check coolant. If it is the same message then it will require a new coolant bottle as they have a known problem with the sensor which is attached.
    This was replaced and it cured my problem.
    Skidmark
  1. A4 Red temperature light staying on
    By dickon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-05-2008, 10:53 PM
  2. Coolant temperature warning light 1.8 turbo
    By The Stagg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2007, 02:55 PM
  3. handbrake light flashing and beeping
    By johnnyboy in forum Passat - Archive Topics
    Last Post: 26-10-2007, 08:13 AM
  4. Beeping TT
    By Bluoranges in forum TT - 8N Forum - 1998 - 2006
    Last Post: 23-08-2007, 09:04 PM
  5. Temperature Warning Light
    By Loach in forum Golf MK3 - 1993 - 1999
    Last Post: 08-11-2006, 01:37 PM
