Thread: dump valve
Results 1 to 9 of 9
  1. dump valve
    I would like a chattering dump valve for my mk4 golf turbo, anyone know of a good one?
    london/ UK
    Try Bailey Motorsport or Forge Motorsport websites. They both do a shiny piston recirculating valve(quiet) that will replace the plastic Bosch jobbie. Noisy dump valves(venting type ones) dont work so well with the 1.8T engine ECU as its verry fussy and complicated and may trigger faults, thus causing limp mode ! There are companies out there that have working venting dump valves that use the accelerator/clutch switch as a trigger and are electronically controlled- supposeddly working for TDI engines as well but dont wonder if your car goes into limp mode or emission lights comme on the screen. Do your research and go for a reputable company/vendor !
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Agreed - bailey and forge do decent ones. Venting ones sound better but recirc ones are more reliable. Not sure if you can get a really chattery noisy recirc one.
    TDI dump valves are a pile of pants. £250 for a thing that goes PSSST when a switch is triggered. Ummm, no ta.
    london/ UK
    Quote Originally Posted by devonutopia View Post
    I agree with you, the dump valve for tdi makes no difference on the engine and brings no improvement at all. Its just one of these gizmos ! I prefer mine stealth...if you know what i mean ! I love the surprise on peoples faces when they see my rear TDI badge !
    Nov 2006
    South West UK
    Adams - I posted recently asking about TDi dump valves - glad I listened to you and saved myself a packet! I've fitted an adjustable boost system, which i've adapted to a genuine VW heated seat switch so nobody can tell what it is, and the boost guage/driver's air vent from SWG motorsport - looks very trick!
    Now that I've raised the boost on the car I get a lovely chatter from the wastegate... Better than a gay electric hissing thing!
    May 2006
    My TDI makes a nice chattery noise from the turbo anyway. Delicious hybrid fitted. Bit smokey though sometimes.
    london/ UK
    Jason, did you tried to lower the injection quantity to minimise the smoke at WOT ?
    Nov 2006
    South West UK
    Sounds good Devon, and clearly goes well! What 'charger are you running?
    May 2006
    I can't lower the injection quantity as thats done by the remapper. The turbocharger is a hybrid VT2 from Allard turbo sport. Unsure of its exact spec, but its being chopped in for a higher spec one soon. Hoping the fuel will all be burned up then.
    At 1.8 bar, the car pushes max torque at 2800rpm (360lb/ft) and max BHP (221bhp) at 3800rpm. The power between 3000 and 4000rpm is awesome.
  1. 1.8t Dump valve
    By Nav_1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-06-2007, 02:15 PM
  2. I Need A Dump-valve!!!
    By dubwizard in forum Archive posts
    Last Post: 21-05-2007, 05:28 PM
  3. S3 Dump Valve?
    By HappyS3Owner in forum Audi A3 - Archive Topics
    Last Post: 25-04-2007, 05:36 PM
  4. **help With Dump Valve Help**
    By scooby in forum Audi A3 - Archive Topics
    Last Post: 23-02-2007, 05:48 PM
  5. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
