Thread: '98 V6 Synchro mis-firing
  1. Exclamation '98 V6 Synchro mis-firing
    Please could anyone offer some ideas as to why my V6 is mis-firing. I understand from what I have already read on other VW models that the problem could be in a number of areas but any help or advice will be greatfully recived. I know that if i don't get this problem fixed the potential knock on effects for the cat etc could be really expensive.
    Regards
    DPR
    london/ UK
    Replace/swap the coils between the cylinders and see if its improving(please note witch piston they from-a marker will help !). Also its worth reading the fault codes as that will narrow the search a bit and post them on the forum. Could be something simple as a knock sensor(camshaft or krankshaft) or could be even coroded connectors to the injectors/ECU or a faulty injectors or the ECU itself. Good luck.
    Thanks for the reply. As a non Technical (well cars anyway) I do have a really good independent VW Audi specialist that Services my Passat and my wife's Audi but he still charges £42 / hr so diagnosing faults like this could take a while. Do you think even though he is an independent he will have all of the diagnostic gadgets that a dealership would (They are called VolksTec....based in Chalfont St. Giles)???
  1. 90 JETTA FIRING SEQUENCE
    By brawley in forum Jetta MK2 - 1984 - 1992
    Last Post: 25-07-2008, 01:57 AM
  2. miss firing
    By sh4h99 in forum Touran - Sharan - Caravelle
    Last Post: 12-07-2007, 11:22 PM
  3. 1994 Audi 80 2.0 (ABK) Not firing
    By vImTo in forum 80 - 90
    Last Post: 09-05-2007, 10:22 PM
  4. Firing on only 3 cylinders
    By Mozza31 in forum Archive posts
    Last Post: 29-01-2007, 01:32 PM
  5. GTi 8v firing problem
    By dgh938peg in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-10-2006, 02:10 PM
