Quote Originally Posted by digigriffin View Post
Here is the way I prepared my SD card.
I used iTunes to make my mp3, which I happen to do for my iPod anyway.
Mount the SD card on pc.
Copy the folder structure onto the the SD card from the iTunes library
To make the m3u
I created the playlists in iTunes.
I downloaded this software that will export your playlists from itunes to m3u.
http://www.ericdaugherty.com/dev/itunesexport/
edit playlist to remove path to itunes library with text editor.
Copy playlist to SD card.
SD card and playlists now ready for use.
Ditto..an excellent solution
But now the latest download lets you export the itunes playlist and MP3's with one click onto the SD card and it does all the file paths at the same time so you don't have to touch it.
Result?
Play list shows on screen, select any song or leave on shuffle etc, etc the MMI finds it...no editing involved.
The only issue now is converting protected AAC files in iTunes to MP3's.
