Thread: Climate Control (1995 model) display blinking and only hot air!
Results 1 to 8 of 8
  1. Climate Control (1995 model) display blinking and only hot air!
    Jun 2008
    I am a newbe in the Audi World. (driven before several BMW's and Ford's).
    I have buy'd some months ago an old Audi A4 B5 (1995) with a AEB 1.8T engine.
    Now I have serious problems with this car.
    One of the problems is the climate control. It is going crazy.
    After switching on the contact, the display blinks with an interval of +/- 2 seconds. It is possible to control it. But.... it only blows very hot air and only through the ventilation openings in the middle of the dashboard, not possible to control it. No air on the window and on your feet.
    I hope so, cause this car drives me really mad. (Already had a defective airco compressor, a window that was broken down, central doorlock that stops, wastegate broken, a lot of rattling sounds are coming from the front wheels last month etc.)
    Thank you very much!
  2. Re: Climate Control (1995 model) display blinking and only hot air!
    Jun 2008
    Picture of my climatronic display type:
  3. Re: Climate Control (1995 model) display blinking and only hot air!
    Jul 2007
    somerset
    8 Post(s)
    If your digital display is flashing intermittently that is caused by a dry solder joint behind the lcd panel, try searching this site for more info as it can be rectified by re soldering the joints (i did mine 5 years ago and still good). As to why its blowing hot air all the time is a mystery to me, even if the digital temp display is on low does it still blow hot. Try adjusting the temp and fan speen and see if you can make it blow cold air. Turn off the recycle button and try that. I did find with mine when the display was flashing it was impossible to adjust anything. Hope this helps, regards Rhencullen1989.
  4. Re: Climate Control (1995 model) display blinking and only hot air!
    Jun 2008
    Quote Originally Posted by rhencullen1989 View Post
    Hi, thank you for your reply.
    It is blowing under all conditions hot air. I can set the temp. and fanspeed (fanspeed works fine), airco on/off, but I can't control the air outlet directions and the temperature. (On the display is shown the right settings, but he doesn't control the air outlet valves)
    My display is blinking in a steady speed for +/- 2 minutes and after that it turns on completely.
    I will remove the panel and resolder this joints first (if they have bad or cranked contacts) and look if everything is solved or not. I hope so :-D
  5. Re: Climate Control (1995 model) display blinking and only hot air!
    134 Post(s)
    2020 Post(s)
    The system has diagnostic capabilities so it makes sense to start with a fault code read.
  6. Re: Climate Control (1995 model) display blinking and only hot air!
    robinwells Guest
    Hi there
    I don't know for sure but I think you can get a fault code by pressing and holding recirc. and pressing air dist. up button. If it works display should show 1C if so press recirc. again to get fault codes. Try audiworld.com to get tech. bulletin of fault codes and details of how to do test.
    good luck and remember if you are not the head armadillo you have to do the dishes!!!!! what does the bit about lead dogs mean or don't I want to know!?
  7. Re: Climate Control (1995 model) display blinking and only hot air!
    134 Post(s)
    2020 Post(s)
    If you are behind another dog you will be staring up its exhaust pipe, if you are in front, the view ahead is rather better.
  8. Re: Climate Control (1995 model) display blinking and only hot air!
    Jun 2008
    I have opened the AC unit today, the solders on the display module are "resoldered" by an amateur. I have resoldered them (see pictures below) and checked them, but still the same error! I have tried to read it out with vagcom, but vagcom can't connect it, too many errors. (every other module in the car is possible to read with vagcom).
    Does anyone have tips for me, what can be wrong? Or maybe a connection diagram of the AC unit. Maybe I can find out with these information what is wrong!
    p.s. the type number is: 8d0 820 043 D & 5hb 006 500-11 (HELLA)
    Old soldering
    Soldering refurbished
    Vag-Com status readout
    Vag-Com reading another module in this car
  1. Replies: 6
    Last Post: 30-07-2015, 01:40 PM
  2. Climate Display Compatability
    By bigmac999mac in forum Audi A4 - Archive Topics
    Last Post: 19-12-2007, 12:07 AM
  3. A2 - Climate Control Display
    By Imartin in forum A2
    Last Post: 09-10-2007, 10:13 PM
  4. getting your climate control reading to display muiltiple options??
    By Seat til I die in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:27 PM
  5. Climate Control Display Intermittent
    By oakhills5093 in forum Archive posts
    Last Post: 06-02-2007, 10:28 PM
