Thread: Broken glove compartment
  1. Broken glove compartment
    Hi Guys
    It is probably because I'm heavy handed but I can't open the glove compartment on my 05 A4. The lever will open but it is not engaging with the lock- really irritating.
    Has anyone else had this problem and does anyone know how to fix it?
    Stu
    1 1 0
  2. Re: Broken glove compartment
    Dec 2007
    theres a thred knockin around telling you how to get it open use the search to find it
  3. Re: Broken glove compartment
    Dec 2007
    found you this
    Same happened to me in an A4.
    open the pasenger door. at the end of the dash there is a panel that comes off with a small screw driver, take off panel to expose the glovebox and in the top right there is the catch for the glovebox, press that in with the screw driver and you glovebox should open. you then undo the screws on the top of the glove box until it falls out, then you can unscrew the lock fron the right hand side and replace.
    its simple enough you just need 3 hands to put it back together.
    and 2 screws at bottom of glovebox
  4. Re: Broken glove compartment
    Dec 2006
    Take a read of this thread for help..
    https://www.vwaudiforum.co.uk/forum/s...ighlight=Glove
    Rick
  1. Replacing Glove compartment door & Rear ashtray
    By Siboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-07-2008, 01:49 PM
  2. First Aid Compartment broken door catch
    By chris_edgar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-04-2008, 08:52 PM
  3. Can a non audi cd changer be fitted to glove compartment of a3?
    By Kel in forum Audi A3 - Archive Topics
    Last Post: 31-03-2008, 03:46 PM
  4. Glove Compartment won't open help
    By missmellyuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2008, 02:07 PM
  5. glove compartment.
    By jamsb in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-06-2007, 11:38 AM
