Thread: List of problems with my 2001 1.8T - anyone else?
  1. List of problems with my 2001 1.8T - anyone else?
    curiousgeorge Guest
    Driver's door thinks it's open when it's shut, only intermitently
    Air noise from the sunroof at high speeds.
    Very quiet rattling sound from the sunroof
    Loud cluncking sound in gearbox ocasionally from 1st to 2nd
    Dec 2006
    1 - Check the door pin... if this is sticking it will cause a fault and show you door is open... (open the door and free the pin off)
    2 - air any seals standing pround on the roof?? is they are sign if rust under the seal... (even a 3mm lift of a seal can create a lound noise at 7MPH..
    3- when the sunroof is closed, is it going fully back into the closed postition?? if you press the sundoor when clsoed is they any play in it.. (try open the drivers open.... put your hand on the glass on the top and put your other arm in the car and place on the glass on the bottom and grip.. try to see if theres any moement... (if you have short arms... find a friend to help.
    Is there any sign of water entering the cabin from the sunroof??
    4- Gearbox... manual of auto?? could be a differnet issue for either, please let me know which box is in there..
    RickT
    curiousgeorge Guest
    Thanks Rick for your suggestions.
    I didn't notice anything sticking out of the door lock. I asked about this when I had some bodywork done and they said it's quite a common fault. If It was something simple I'm sure they would have sorted it for me. I'll have another look.
    The sunroof is waterproof and seals are not proud and there's no rust. As far as I can tell it closes fully with no apparent play.
    The gearbox is manual.
    George
    Dec 2006
    just going back to the door pin... i meant the door pin swtich next to the hinges on the door.. check that area.
    RiCKT
    curiousgeorge Guest
    Ah, I was looking at the door catch.
    Thanks!
    Dec 2006
    no worries... let us know if you resolve this..
    RickT
    curiousgeorge Guest
    Hi Rick,
    Thanks for your help but I had a look at the hinges area and there was no pin of any kind.
    For some reason the problem is less frequent now.
    George
  1. New Passat - the list of problems grows!
    By AndrewT in forum Passat - Archive Topics
    Last Post: 30-08-2007, 01:23 PM
  2. 2001 Leon problems.
    By bluebaron in forum Leon
    Last Post: 26-04-2007, 11:08 AM
  3. A3 2001 1.9TDI power problems
    By ian2007 in forum Audi A3 - Archive Topics
    Last Post: 16-04-2007, 07:26 PM
  4. Problems with 2001 A4
    By bamjimpat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2007, 02:47 PM
  5. 2001 Passat steering problems
    By lalaland in forum Passat - Archive Topics
    Last Post: 07-06-2006, 12:38 PM
