Thread: Passat TDI 1998 AFN Dies when cold
Results 11 to 20 of 27
  1. Re: Passat TDI 1998 AFN Dies when cold
    Las Vegas! eerrrr OK Hawkwell Essex
    on the scanner the MAF % reading comes up 0.00000% all the time.
    But the MAF has just had a new one fitted.
  2. Re: Passat TDI 1998 AFN Dies when cold
    135 Post(s)
    2038 Post(s)
    Once it is disconnected, the ECU defaults to using the air intake temperature and a base map to determine the engine temp, if the sensor tells the ECU it is -40°c it will fuel accordingly, its up to you anyway.
  3. Re: Passat TDI 1998 AFN Dies when cold
    Jun 2006
    UK, Mids
    If the -40c is given by the high resistance of a faulty sensor, then when disconnected, the same -40c or thereabouts will be given. They are cheap enough at ECP and GSF and are a common failure, so you may as well replace, they are practically a consumable.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Passat TDI 1998 AFN Dies when cold
    Up Date !!
    changed the temp sender no different.
    Took the EGR valve off and cleaned it up checked that it works ok.
    (Inlet manifold from the air in take on the intercooler was rather choked up) (needs stripping down really)
    Still the same.
    Any ideas folks???????
  5. Re: Passat TDI 1998 AFN Dies when cold
    135 Post(s)
    2038 Post(s)
    When it has cut out, you said it does not start easily again, does it sound odd, as if there is no compression? If you drive slower and don't rev it hard, I presume you can drive around this until it warms up and then it is OK?
  6. Re: Passat TDI 1998 AFN Dies when cold
    Got it!
    It sound odd, as if there is no compression.
  7. Re: Passat TDI 1998 AFN Dies when cold
    #17
    135 Post(s)
    2038 Post(s)
    Which grade of oil are you using?
  8. Re: Passat TDI 1998 AFN Dies when cold
    #18
    15W/40.
    you must be reading my mind.
    I have just changed this evening to 10W/40semi synthetic
  9. Re: Passat TDI 1998 AFN Dies when cold
    #19
    seems to run smoother.
    but I haven't tried it from cold yet. ( I will try it tomorrow)
  10. Re: Passat TDI 1998 AFN Dies when cold
    #20
    135 Post(s)
    2038 Post(s)
    I think you are suffering from tappet pump up or jacking as it can be known, I have had this with the earlier TDI engines that use the direct drive pump in sump, rather than the later chain driven type. On the ones I have battled with this we tried a new oil pump, tappets and even dropping down to a 0w/50 oil and all we succeed in doing was reducing the warm up time it suffered from this problem and moving it up the rev band quite a lot but I could not completely cure it.
  1. starts from cold & Dies - BUT
    By robmar0se in forum Leon
    Last Post: 12-04-2008, 06:02 PM
  2. 1998 Passat VR5
    By AlB in forum Passat - Archive Topics
    Last Post: 24-10-2007, 06:29 PM
  3. 1998 Passat Red D Red I
    By joefish in forum Passat - Archive Topics
    Last Post: 29-08-2007, 10:07 PM
  4. Passat 1998 1.9Tdi, Audi A3 1998 1.8
    By sia3 in forum New Member Introductions
    Last Post: 05-03-2007, 10:51 AM
  5. 1998 110 TDI dies with revs when cold
    By Antony in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2006, 02:57 PM
