Thread: Passat TDI 1998 AFN Dies when cold
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Passat TDI 1998 AFN Dies when cold
    Las Vegas! eerrrr OK Hawkwell Essex
    Hi again folks
    I thought my car would never die but its not running to well.
    Start it up from cold and drive away its OK unless I give it to much throttle then it dies with loads of black smoke and it takes a few minutes to restart again. But once the temperature gets to normal I can floor it no problem its just when its cold.
    Any ideas?
  2. Re: Passat TDI 1998 AFN Dies when cold
    135 Post(s)
    2038 Post(s)
    A fault code read first, possibly the coolant temperature sender.
  3. Re: Passat TDI 1998 AFN Dies when cold
    Thanks for that, someone else did mention that.
    I will put it on the scanner tomorrow.
  4. Re: Passat TDI 1998 AFN Dies when cold
    But then why does it chuck out the black smoke and stall?
    Is it over fueling?
  5. Re: Passat TDI 1998 AFN Dies when cold
    135 Post(s)
    2038 Post(s)
    If the coolant temp sender is telling the computer that the engine is at -40°c then it will over fuel just a bit but EGR problems can also cause this symptom. Whatever, a fault code read, print, clear, drive and re-read and print is the first thing to do, it helps prevent time and money wasting guess work.
  6. Re: Passat TDI 1998 AFN Dies when cold
    Just an up date.
    I scanned it this morning, nothing came up, cleared it re-scanned still nothing. As the temperature got to about 33 degrees I revved it hard the usual happened it ran lumpy smoked a lot and died (tried to keep it running) managed to restart it and I noticed the temperature reading on the scanner was -40 (spot on there Crasher :-) ) but the reading on the dash was about 30 ish. I gave some light revs and she ran smooth and the scanner reading then went to 65 degrees and she then runs OK. Once warmed up she runs fine.
    looks like you were right Mr Crasher. Thank you.
    I will let it cool down and give it another scan but I will probably invest in a temp sender.
  7. Re: Passat TDI 1998 AFN Dies when cold
    more up date.
    Tested the temp sender unit with the meter as per autodata. all ok.
    I tried running the motor with it disconected but no different.
    back to square one...
  8. Re: Passat TDI 1998 AFN Dies when cold
    135 Post(s)
    2038 Post(s)
    Change the sensor and see how it goes. If you keep the revs down, does it drive OK and then rev properly when hot? It is difficult to start again after the cut out, sounding different to how it normally sounds when being cranked over?
  9. Re: Passat TDI 1998 AFN Dies when cold
    Thats spot on there. all of the above
  10. Re: Passat TDI 1998 AFN Dies when cold
    Couldn't see the point in changing the sensor if it makes no difference once its disconnected.
  1. starts from cold & Dies - BUT
    By robmar0se in forum Leon
    Last Post: 12-04-2008, 06:02 PM
  2. 1998 Passat VR5
    By AlB in forum Passat - Archive Topics
    Last Post: 24-10-2007, 06:29 PM
  3. 1998 Passat Red D Red I
    By joefish in forum Passat - Archive Topics
    Last Post: 29-08-2007, 10:07 PM
  4. Passat 1998 1.9Tdi, Audi A3 1998 1.8
    By sia3 in forum New Member Introductions
    Last Post: 05-03-2007, 10:51 AM
  5. 1998 110 TDI dies with revs when cold
    By Antony in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2006, 02:57 PM
