Thread: water collecting in battery compartment
Results 1 to 10 of 12
  1. water collecting in battery compartment
    May 2008
    I have just noticed a lot of water in the battery compartment, and I am concerned this will rot steel or leak into the cabin. Should there be a drain hole and if so, where is it?
  2. Re: water collecting in battery compartment
    May 2007
    knee deep in clunge
    14 Post(s)
    https://www.vwaudiforum.co.uk/forum/s...er+leak&page=2 unblock the grommet and clean out the drain channels
  3. Re: water collecting in battery compartment
    134 Post(s)
    2013 Post(s)
    A huge problem on the Passat, Superb, A4 and A6. If it gets high enough it will spill over into the heater inlet, flood the floor on the passenger’s side and cause problems with the central locking system. If the servo sits in water (as it does when this happens) it will slowly draw water in and this will cause the brakes to jam on, starting with the left front. Cleaning the drain tubes out (one under the battery tray and one under the servo) takes about half an hour.
  4. Re: water collecting in battery compartment
    Jun 2008
    I had the same problem, you need to remove battery & battery tray. There are two drain holes, one under battery the other underneath brake servo. Both can block with debris, leaves etc.
  5. Re: water collecting in battery compartment
    Jul 2007
    Wicklow, Ireland
    Tell tale signs are dampness in the passenger footwell....OR more condensation than normaal on the windscreen. It's one of those things that if checked during services can save £££ later on..
  6. Re: water collecting in battery compartment
    May 2007
    Warning, i had exactly this problem on my 1.8t 2000 w Passat saloon shortly after getting it and took the battery out to unplug one of the holes and when connected it back up the car went in to limp mode, the VAG technician from the dealer i bought it from said that with 2000 models some cars do this, which is a pain so if i need a new battery i have to go to VW and then get them to reset the engine!! This is not in owners manual as i checked what things needed to be reset. Good luck hope yours isn't one that limps!
  7. Re: water collecting in battery compartment
    134 Post(s)
    2013 Post(s)
    Only the petrol models get upset by disconnecting the battery due to the adaptation of the throttle body being lost and it will be worse if the throttle body is very dirty.
  8. Re: water collecting in battery compartment
    Tyldesley, Manchester, UK
    Last time I had the problem I did dis-connect the battery to remove it. It was off for about 1/2 hour but never had any problems afterwards. Is it just hit and miss or is there a time limit on the battery being disconnected?
    One German, Two Italian.
  9. Re: water collecting in battery compartment
    134 Post(s)
    2013 Post(s)
    It is hit and miss but perhaps your throttle body is quite clean.
  10. Re: water collecting in battery compartment
    Cheers, quite good news then.
  1. Whats that compartment for then?
    By meathead in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2008, 08:51 PM
  2. Boot compartment
    By Michelin in forum Golf MK4 - 1999 - 2004
    Last Post: 07-04-2008, 03:01 PM
  3. Water build up in battery area
    By E30_GN in forum Passat - Archive Topics
    Last Post: 04-07-2007, 05:22 PM
  4. Water hanging under battery
    By vroooOOOM in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 17-06-2007, 10:10 PM
  5. glove compartment.
    By jamsb in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-06-2007, 11:38 AM
