Thread: Clutch Question / Query
  1. Clutch Question / Query
    May 2008
    Hi
    I took my 2006 A4 2.0 TDi SE (I have only had it three weeks) to the dealer this week as I thought there was a fault with the clutch.
    The issue I reported was :-
    I get a vibration from the clutch pedal when touching it lightly or changing gear (not when it is released or fully depressed but in between) - the dealer has told me there is no fault with the clutch and this is a 'characteristic' of this type and age of car, and there is nothing they can do.
    Has anyone else noticed this clutch 'characteristic' ? I personally find it annoying, and find it let's the car down - for those folk who also found it annoying ; did you get used to it ??
    Thx
    Alan
  2. Re: Clutch Question / Query
    Dec 2007
    In relation to your brake pedal would you say your clutch pedal is the same hight or is it a bit higher ???
  3. Re: Clutch Question / Query
    May 2008
    I just checked - and the clutch pedal is slightly higher than the brake pedal ..
  4. Re: Clutch Question / Query
    Dec 2007
    I have an A4 05 plate,and my clutch feels grindy not smooth, there is no judder as such, but it just does not feel smooth I just think the clutch on the Audi A4 is quite basic and does not have the quality of other models.
    When I touch my cluth slightly I also get the feel of vibration, and every so often first gear is difficult to engage. Hope this helps
  5. Re: Clutch Question / Query
    May 2008
    thanks for the reply ... your clutch sounds similoar to mine
    did you get used to it in time ?
    thx
    Alan
  6. Re: Clutch Question / Query
    Dec 2007
    Yes I did get use to it after a while, the a4 is a heavy car compared to the passat I had,maybee the clutch is a belt and braces job.
  1. Clutch Query
    By BuyanythingbutaVW in forum Golf MK5 - 2004 - 2009
    Last Post: 05-05-2008, 11:24 PM
  2. Im so Annoyed (Clutch Question)
    By tsunami in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2008, 07:46 PM
  3. Clutch Query
    By Jak68 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2007, 11:52 AM
  4. Clutch question
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 25-09-2007, 08:16 AM
  5. 1.9tdi gearbox and clutch query?
    By white_lightning in forum Passat - Archive Topics
    Last Post: 02-04-2007, 10:44 AM
