Thread: Mk4 1.8Gti starting problems & high idle revs
  1. Mk4 1.8Gti starting problems & high idle revs
    May 2008
    i've got a 2000 X plate gti 1.8t 150bhp with 110k on the clock. it's been really reliable for 4 years but recently has problems starting: basically -
    • sometimes (prob 70% of the time) it starts fine, like new, no accelerator needed to start
    • other times, it will take 5-10 seconds to start, and only if i pump the accelerator pedal hard. In these cases, when it starts the engine seems to vibrate a lot and some dark smoke comes out of the exhaust temporarily, then it;s ok
    • sometimes when it is idleing after starting the engine, it will idle at around 2500 revs, rather than usually just under 1000.
    • it doesn't seem to make any difference whether the engine is hot or cold. if anything, it normally starts fine, first time each morning. then when i restart it during the day i have the problems.
    any thoughts? all ideas appreciated and anything that i could try myself rather than having to take to a mechanic would be great.
    thanks in advance
    John
  2. Re: Mk4 1.8Gti starting problems & high idle revs
    May 2008
    wales
    Quote Originally Posted by jroberts060 View Post
    thanks in advance
    John
    hi m8 hav u got vagcom if not i hav where do you live when was the lst time you serviced her,
  3. Re: Mk4 1.8Gti starting problems & high idle revs
    133 Post(s)
    1986 Post(s)
    You need a fault code read and that will more than likely show you have a faulty coolant temperature sender.
  4. Re: Mk4 1.8Gti starting problems & high idle revs
    May 2008
    wales
    its not ur temp senor m8 i had a dodgey temp senor and my car was not doin what urs is somthink else wrong there m8
  5. Re: Mk4 1.8Gti starting problems & high idle revs
    133 Post(s)
    1986 Post(s)
    So it isn't what I might think it may be but it is something else, very helpful!
    This post may also be of interest.
    https://www.vwaudiforum.co.uk/forum/s...ght=text+speak
  6. Re: Mk4 1.8Gti starting problems & high idle revs
    Mar 2008
    Quote Originally Posted by 18turbo View Post
    id say new temp sender,i had a similar fault and that is what it turned out to be,plus id listen to crasher the bloke knows all!
  1. 99 plate 1.8 revs are high on automatic
    By Maz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-11-2008, 04:45 PM
  2. NEED HELP!! overheating on high revs
    By tony19 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-03-2008, 02:59 PM
  3. Help! A3 1.8t Idle/Low Revs Running Problems!
    By al_clinton in forum Archive posts
    Last Post: 10-02-2008, 09:39 PM
  4. Kangaroo-ing at low revs and Revs staying high on Gearchange.
    By Dancake in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 05:50 PM
  5. High revs when idle
    By poseidon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 07:46 PM
