Thread: Headlight Bulbs
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
  1. Headlight Bulbs
    Scunthorpe
    Has anyone changed their standard headlight bulbs from the standard (non Xenon ones) to something a bit brighter? If so, what did you change them to and how easy was it?
  2. Re: Headlight Bulbs
    Nottingham
    I have an 08 Sport and swapped mine for some HIDs, 6000K units. The swap was quite easy, a bit fiddly, but do one at a time and refer to the other while you go and it shouldn't take more than 30minutes or so. The light output from the HIDs is totally different but much much brighter than standard bulbs.
    Do it!
  3. Re: Headlight Bulbs
    Scunthorpe
    Where did you get them from? Is there a part number I need to be aware of? And will they need adjusting afterwards?
    And I will
  4. Re: Headlight Bulbs
    Apr 2007
    France
    12 Post(s)
    Found this in Wikipedia:
    "European vehicles equipped with HID headlamps are required by ECE regulation 48 also to be equipped with headlamp lens cleaning systems and automatic beam levelling control. Both of these measures are intended to reduce the tendency for high-output headlamps to cause high levels of glare to other road users."
    1996 Laguna 2.2D
    1977 MGB roadster
  5. Re: Headlight Bulbs
    Scunthorpe
    Hmm - food for thought...
    I do however have a manual lens cleaning system and manual beam control
  6. Re: Headlight Bulbs
    Nottingham
    James,
    The kit I used was bought from a guy on another forum but to be honest they're pretty much all the same, with the exception of some of the latest kits which have super slim ballasts. To prove this, I bought some from a guy based in China selling cheap kits on ebay. All three kits worked perfectly.
    With regards to European regs on auto cleaning etc, I'm with you. My car is kept very clean, especially the lights, as when required they are extremely critical to safe driving. The reason they were changed in the first place is that the standard lights are pretty poor so imagine the light output if they were to get dirty; and with no auto clean feature they may as well not be there! That's how I would argue it with the police around here.
    The Passat projectors (I assume you have them fitted) do a very good job of preventing glare so again, I'd argue that with anybody. The standard VW HID kit may have slightly different projector lenses (I don't know, just commenting) but your average plod isn't gonna be able to spot that. And anyway, I live in Nottingham so if he hasn't got something better to be doing he needs to take a look at his priorities! Also, I've never had anybody flash me for causing glare and to prove the point, I drove around with the lights on their highest setting for a while to see if anybody complained.
    As I said, get on and do it. Have a look on Autobulbs.co.uk for some U.K. kits, think they were £99 last time I looked and with decent replacement bulbs costing £15 each, I know what I'd spend my money on. Alternatively, check out the guy on ebay. Delivery took 4days from China which is very impressive and the total price, including shipping was £34. Make sure you order the correct kit though and don't rely on his applications guide. I bought some for my motorbike and his guide was incorrect. Can't remember off hand the bulb size and am away for the next week and a bit, but I'm sure somebody on here can help.
    Is this the longest post ever?!?!?
  7. Re: Headlight Bulbs
    Quote Originally Posted by Feeex View Post
    James,
    The HID headlamp units do look different, the projector lens is mounted in a 360 degree swivel mounting and the side lights have a pronounced circular lens, but the main tell tale sign is the cut in the bumper for the washer jet to pop out of! Can you tell I've been headlamp spotting recently?
    I wouldn't risk fitting HIDs because they'll probably invalidate your insurance but you'll only find out when you need it and by that point it will be too late!
  8. Re: Headlight Bulbs
    Rutland
    Quote Originally Posted by garrad View Post
    Hadn't thought of that but did wonder about potential MOT failure. If its in the ECE regs.then it ought to be part of the MOT check, didn't it?
    Passat Estate GT 16 190/295 DSG Sand Gold/Espresso, Premium LEDs, Area View, DA Pack Plus, Park Assist, XDS, Boot divider, Olive Ash.
    TDI history, all saloons: CC 59 140/236 GT, Passat 06 140/236 Sport, A6 SE 2000 110/173, A4 SE 1995 90/149, 80 1992 90/134, plus SWMBO's 2000 A3 SE 90/155 hatch.
    1979 Alfasud 4 door 1.5 in Verde Pino. 105 bhp Green Cloverleaf engine .
  9. Re: Headlight Bulbs
    Scunthorpe
    James,
    Yes, yes it is
    Who did you buy the kit from and who was the seller?
  10. Re: Headlight Bulbs
    Sep 2007
    South Manchester
    Did them a while back
    Re: Xenon lights or not?
    I fitted my Philips X-treme bulbs yesterday, a little tricky but not too bad.
    Def improvement over Std Philips Long Life H7's.
    VW Passat Estate 2.0 TDI DSG in Silver 2006
  1. Question Brighter Headlight Bulbs?
    By psiron in forum Golf MK5 - 2004 - 2009
    Last Post: 01-06-2009, 02:58 PM
  2. Changing headlight bulbs
    By Stuart W in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2008, 06:06 AM
  3. Headlight Bulbs
    By Michelin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 02:42 AM
  4. Headlight Bulbs - Main Beam
    By Ben in forum Chat - Anything with wheels
    Last Post: 11-12-2007, 10:16 PM
  5. Headlight switch bulbs gone
    By madfella65 in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 08:35 PM
