Thread: black metel bits holding in glass in rear window..
  1. black metel bits holding in glass in rear window..
    May 2008
    mine are quite eroded, is this possible and easy to replace, as its part of the window frame?
  2. Re: black metel bits holding in glass in rear window..
    135 Post(s)
    2043 Post(s)
    £14.50 per side, major strip down to fit.
  3. Re: black metel bits holding in glass in rear window..
    May 2008
    what would you class as a major strip down?
  4. Re: black metel bits holding in glass in rear window..
    135 Post(s)
    2043 Post(s)
    Door cards off, door inner panel and window mechanisms with lock units out, glass out and then remove the guide (or middle carrier as it is also known).
  5. Re: black metel bits holding in glass in rear window..
    135 Post(s)
    2043 Post(s)
    The little filler piece is £7 and nearly as much work to fit.
  6. Re: black metel bits holding in glass in rear window..
    May 2008
    jesus, its something i want done, but cant do myself. i suppose it would cost me a bomb at a dealership
  7. Re: black metel bits holding in glass in rear window..
    135 Post(s)
    2043 Post(s)
    I would say it’s about an hour and a half per side so at dealership rates of £100 an hour I would find a specialist but you are still looking at £150 for labour.
  1. info. needed on replacing rear n/s door glass. Is it easy to do?
    By tonos in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2008, 02:06 PM
  2. A6 smoked black rear lights.
    By a6rob in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-01-2008, 12:32 AM
  3. Rear window won't roll up/down
    By nismogirlb14 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-01-2008, 08:52 PM
  4. Removing rear passenger door glass
    By proworldinc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-12-2007, 01:41 PM
  5. interior trim bits and a rear lamp wanted A6 avant
    By fastcars in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-06-2007, 11:13 AM
