Thread: air con still not working on a4 tdi 2002
Results 1 to 10 of 15
  1. air con still not working on a4 tdi 2002
    May 2008
    hi all,
    i have a 2002 a4 tdi 130bhp. The air con is not working as the econ button on the climate control remains illuminated. On pressing the econ button the lights goes out but then reappears after 1 sec. I have recently had it regassed by a specialist and found the following code on vagcom: under air con climate control
    00819 - High Pressure Sensor (G65)
    30-00 - Open or Short to B+
    Anyone have any ideas.
    regards jason
  2. Re: air con still not working on a4 tdi 2002
    Feb 2007
    Had the same problem on mine it was the high pressure switch easy diy job get the switch from audi and change it yourself. The switch is behind one of the headlights I think its the drivers. The switch is self sealing and screws into the air con rad.
  3. Re: air con still not working on a4 tdi 2002
    Witney
    I had the same and just changed it as 'spainy' just said. Make sure you get a new o ring as well because it does not come with the new sensor and you have to buy it seperately.
  4. Re: air con still not working on a4 tdi 2002
    May 2008
    Quote Originally Posted by afghandaz View Post
    I have the same problem on my 2.5 TDI, does anyone know the HPS part no. and the price??
    Cheers Murph76
  5. Re: air con still not working on a4 tdi 2002
    Witney
    https://www.vwaudiforum.co.uk/forum/s...ead.php?t=3375
    err dont know if i have done it right but go through the above thread and all the details are there.
  6. Re: air con still not working on a4 tdi 2002
    May 2008
    I will give this a try.
  7. Re: air con still not working on a4 tdi 2002
    Aug 2007
    Cumbria
    Hi folks,
    I've been having similar problems - econ light won't go out. The garage says the error code is:
    0333 HIGH PRESSURE SENSOR SIGNAL TOO LOW - SIGNAL TOO LOW STATIC
    This doesn't seem to be exactly the same message that others have had.
    Does anyone know if this may mean that just a re-gas is needed or does it mean I need a new switch?
    ANy advice gratefully received!
    Nigel
  8. Re: air con still not working on a4 tdi 2002
    May 2008
    Hi Mate,
    Exactly the same as mine. I changed the high pressure switch which cost about 30 pounds and presto, away she worked fine!!!
  9. Re: air con still not working on a4 tdi 2002
    Aug 2007
    Cumbria
    Hi kangtdi. Great news - thanks for replying so quickly.
    Is it an easy enough job? It seems not too bad from what people say but I'm no mechanic! It was just in getting the cam belt and water pump changed and I asked them to read the fault codes. I told them I thought it was the switch and they could have just changed it while the front was off but they wouldn't touch the air con though because of health and safety...
  10. Re: air con still not working on a4 tdi 2002
    May 2008
    hi please dont panic about this. it is an easy job, you wont have to take the front off, its by the side of the front radiator passenger side. you can do it yourself although i got my mechanic to do it. you will need two 17mm spanners. Good luck. you're aircon will work straight away. providing it has gas in it.
    kind regards
  1. Mk6 2002 Polo power steering not working
    By italianjob in forum Polo - Derby - Lupo - Fox
    Last Post: 18-03-2008, 10:54 PM
  2. Replies: 3
    Last Post: 26-12-2007, 11:36 PM
  3. Passat TDI 130 2002 Interior blower vent lights not working!
    By radek2008 in forum Chat - Anything with wheels
    Last Post: 19-10-2007, 07:00 PM
  4. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
  5. Advice needed..Indicaters not working 2002 Golf
    By kennyb in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-05-2007, 07:32 PM
