Thread: Slight vibration on idle
Results 1 to 8 of 8
  1. Slight vibration on idle
    Dec 2006
    Hi all,
    I have a 2001 A4 tdi 1.9
    The car vibrates a bit more than one would expect when idling(although the rev needle remains very still), but this smooths out if I switch on the aircon fan. Is this idling setting or maybe a mounting issue?? also when I hit 140km per hour.....naughty I know....it vibrates slightly. I have done wheel balancing and still the same thing.
    cheers guys
    Saffer
    ps. its 27degrees in Durban today and im just off to the beach
    Dec 2006
    When you say turn the AC on???
    do you mean press the ECON button to turn the aircon off?? (so the Red LED is on??)
    Is this a B5 or B6 as it changed in 2001..
    Also 140KM is not naughty......... i tend to say just under 90-100mph... which is about 160KM.... unless its a very clear bit of motorway...... i have had it up to 135MPH (217KM) but then bottled it... ...
    Obviously on a private track.................
    RicKT
    Dec 2006
    Hey Rick,
    Thanks for the reply, ill have to check the B5/B6 issue. When I put aircon on (not econ) and take the fan up to about 3 or 4 of the "bars" you see on fan strength displaythe vibration stops. I tend to think it is not idling issue as I said the rev needle is very stable. Do you think its a mounting bracket or something
    Have been up to 270kph but that was a M3 CSL driven by a mate who is a race driver.....scary stuff
    Rian
  4. Exclamation
    Dec 2006
    Heres the model list below...
    B5
    1996-2001.5 Audi A4 / 2000-2002 Audi S4 & Audi RS4
    B6
    2001.5/2002-2005 Audi A4 & Audi A4 Cabriolet / 2004 Audi S4
    B7
    2005.5+ Audi A4, Audi RS4 & Audi S4
    RickT
  5. B6
    Dec 2006
    Hi Rick,
    I believe the one I have is the B6 model.
    Saffer
  6. Post Vibration
    Nov 2006
    I mite be incorrect on this but i think your Air Filter may need cleaning out...
    I had the problem in my Golf that the cars Idle meter jumped ever so slightly making car bounce...
    Im sorry if this aint helped.
    Dec 2006
    Air filter wont make it run rough... unless it complety blocked...
    Start off by doing a quick simple service... Air filter, oil Filter, Oil,
    also... im thinking it could be B5 as the B6 does not have a button which say AIRCON or A/C
    Is yours like this... B5
    http://cgi.ebay.co.uk/AUDI-A3-A4-CLI...ayphotohosting
    or like this B6..
    http://cgi.ebay.co.uk/AUDI-A4-CLIMAT...ayphotohosting
    RicKT
    Dec 2006
    Hi Rick,
    I believe I have the same unit as the B6.
    But following on from Anzee's suggestion the car has allready been booked for a scheduled service on the 17th Jan with the ***********. I will let you know after if that did the trick.
    Cheers guys and thanks
    Saffer
  1. A4 Avant vibration
    By ian5509 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-05-2007, 11:06 AM
  2. Vibration
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2007, 02:56 PM
  3. Slight 'hesitation' at idle
    By darren74 in forum Passat - Archive Topics
    Last Post: 16-02-2007, 12:37 PM
  4. Slight rattle on cold morning MK4 Gold TDI150
    By aoyk11 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-06-2006, 10:49 PM
  5. Slight Tapping, whirring sound
    By Whitie in forum Archive posts
    Last Post: 10-02-2005, 10:30 AM
