Thread: Mk 4 Estate Tailgate wont Unlock help please
  1. Mk 4 Estate Tailgate wont Unlock help please
    Currently on holiday in Spain and tailgate on mk4 VW Golf 2004 Estate refuses to open, nothing was there to jam the mechanism, release motor is working but sounds a little slow have checked all fuses and blasted wd40 into the key hole and through the numberplate light openings and also sprayed into lock mechanism from inside at bottom of door
    Can anyone help or at least advise how to open tailgate please
  2. Re: Mk 4 Estate Tailgate wont Unlock help please
    133 Post(s)
    1988 Post(s)
    You will have to remove the liner from inside. I have never seen this happen on a Golf 4 estate but on the hatch it is usually the result of water leaking from the rear wiper motor.
  3. Re: Mk 4 Estate Tailgate wont Unlock help please
    get in the boot look where the pull down handle is and take out the 2 screws the pull the panel off, look in the center of the boot lid and find the latch sound like the rod has popped off from the handle or latch give the rod a pull if it's still on the latch or put your hand in and see if you can pull the lever on the latch that has a white clip on. once open see if you can put the rod back on.
  4. Re: Mk 4 Estate Tailgate wont Unlock help please
    Many thanks for both of your replies, had already tried removing the liner panel by taking out the 2 screws as it didnt remove easily didnt want to force it out, will have another go at it, regards
  5. Re: Mk 4 Estate Tailgate wont Unlock help please
    133 Post(s)
    1988 Post(s)
    The metal clips take a really good pull to overcome, it feels like you are going to break it, and occasionally you will.
  6. Re: Mk 4 Estate Tailgate wont Unlock help please
    Once again cheers all for your advice, it did need a hefty tug to pull free but came away ok when I got more aggressive with it!
    The actuating arm had come off the the latching mechanism so just replaced it and its been fine since
    Rear panel was easy to refit too, just had to pull away and refit a few metal clips that had stayed in the door and had come away from the panel
    Now back in UK
  1. Tailgate Unlock problems- need a definitive answer
    By gav_j_crompton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-12-2008, 06:22 PM
  2. Tailgate wont unlock
    By Matt Lilley in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2008, 10:29 PM
  3. Rear drivers side door wont unlock.
    By mickyd1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 03:03 PM
  4. Audi 80 TDI Estate Tailgate
    By stillgrinning in forum 80 - 90
    Last Post: 21-02-2008, 10:02 AM
  5. All Doors Wont Unlock
    By elmoreno1785 in forum Passat - Archive Topics
    Last Post: 05-05-2007, 11:06 AM
