Thread: Front end loose?
  1. Front end loose?
    May 2008
    Southern Counties
    Hi guys, new to the forum but been reading it since i got my A3 last december.
    My A3 has been great since i brought it, but one thing has bothered me, everytime a go over a speed hump or just bad road surface the front axle doesnt sound as 'solid' as i think it ought to. Almost as if its loose?!?
    I reported it to the Audi dealer the first time and they said that the rear shocks needed changing and it was a common fault, that was done under warranty no probs but the front still hasnt sounded 'solid'.
    Its going in for a service tomorrow as i've racked up the milage since having it and have asked them to check again but i always get the same response that they can never reproduce it!!
    Has anyone got any ideas what it could be? I have read about a knocking noise from the front when stearing which isnt happening.Mine is only when i go over a bump with the wheels straight.
    A3 2.0 tdi (140) '53
  2. Re: Front end loose?
    Feb 2007
    kent
    Thats your front anti roll bar bushes, its not dangerous just annoying
  3. Re: Front end loose?
    May 2008
    Southern Counties
    So is that something that every A3 suffers from or just some? If its just some i want to get it done on warranty (if Audi will do it!!)
    Thanks for the reply!!
    A3 2.0 TDI '53 Plate
  4. Re: Front end loose?
    Gloucestershire
    Agree on the anti-roll bar bushes, just done mine, also check the drop links too, another weak spot on the A3.
    Audi A3 1.8 20v 1998
    Audi A6 2.5 TDi 1996
  5. Re: Front end loose?
    134 Post(s)
    2021 Post(s)
    Agreed, front anti roll bar corroded under the bushes is the most likely cause, this is a very common problem on modern VAG products. Another problem I come across that sounds like it is from the front is the rear axle bushes, strange but true.
  6. Re: Front end loose?
    May 2008
    Southern Counties
    Thanks guys, cars going back in on thursday so will call them and ask if they can do it under warranty!
  1. Loose Door Handle
    By Piez in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2016, 05:12 PM
  2. Loose Wire????
    By Abbs985uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-02-2008, 09:52 PM
  3. loose intercooler pipe! please help!
    By y2mash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-09-2007, 05:17 PM
  4. Loose wire
    By Cara2007 in forum Archive posts
    Last Post: 27-04-2007, 11:23 PM
  5. Loose Gearbox
    By mUNKI in forum Golf MK2 - 1984 - 1992
    Last Post: 13-10-2006, 10:50 PM
