Thread: Golf GTi 2.0 misfire and stalling
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. Golf GTi 2.0 misfire and stalling
    Mar 2008
    Hello and thanks for looking.
    I have just bought a mk3 N-reg 2.0 golf GTi 16v. It seemed to run ok but had a slight misfire, now the misfire has got worse and is realy bad after reving the engine. It starts and idles ok but when I drop the cluch after reving it misses and stalls. This now happens all the time even when changing gear the engine stalls.
    I have changed the plugs, leads, airfilter & fuel filter.
    Please help as I am starting to thing this was a real bad buy!
    Phil
  2. Re: Golf GTi 2.0 misfire and stalling
    131 Post(s)
    1974 Post(s)
    Change the ECU relay first, at position 3 on the fuse box with “30” printed on top. It is available from VW under part number 165 906 381 for about £12. If that fails to cure it, have a fault code read done.
  3. Re: Golf GTi 2.0 misfire and stalling
    Mar 2008
    Wow super fast reply!!
    Thanks a lot mate, I will try this as soon as I can pick that part up. I can live with an extra 12quid to fix.
  4. Re: Golf GTi 2.0 misfire and stalling
    If that doesnt work, the next popular is the fuel pump relay (167).
    Does the car start straight back up?
  5. Re: Golf GTi 2.0 misfire and stalling
    Mar 2008
    Yes it starts up ok straight after. I can hear a misfire right through the revs that seems to get worse once warmed up. Car will idle ok (with a slight mis) until I rev the engine over 2000rpm, then as the rpm drops it misses and pops and the revs just seem to drop off.
    Its almost like its getting too much fuel or the fuel isnt cutting off after high rpm and its flooding the plugs?
  6. Re: Golf GTi 2.0 misfire and stalling
    I would look into the fuel pump relay. They are £23 ish form vw.
  7. Re: Golf GTi 2.0 misfire and stalling
    Mar 2008
    Do these go quite often? What about the inlet manifold, would this cause this problem?
  8. Re: Golf GTi 2.0 misfire and stalling
    They are quite common apparently. I read somewhere else today that if you car struggles after dipping the clutch, that it could be a dirty throttle body.
  9. Re: Golf GTi 2.0 misfire and stalling
    Mar 2008
    Just been looking at that today, it dosen't look to dirty. Plus I dont think that would make it misfire right through the rpm range? I'm going to clean it a bit anyhow and try to chech the inlet manifold. then I'll phone VW and order the relays posted on here.
  10. Re: Golf GTi 2.0 misfire and stalling
    I wish you luck with your problem. Mine is going back to the auto electricion tomorrow. It runs for ten mins and then will cut out. It then shows no spark to plugs. I have just changed the HT leads, distributor cap and rotor arm and the ignition coil. Its very annoying
  1. Stalling mk3 Golf
    By Chel$ea in forum Golf MK3 - 1993 - 1999
    Last Post: 15-01-2008, 12:14 AM
  2. mk3 golf 2.0 gti electrical nightmare + stalling???
    By pye in forum Golf MK3 - 1993 - 1999
    Last Post: 06-08-2007, 08:44 PM
  3. Golf V5 Stalling
    By Trucypriot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-03-2007, 09:18 PM
  4. Mk3 Golf engine stalling
    By Kero in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2007, 11:37 PM
  5. VW GOLF V5 ~ Overheating + Stalling?
    By artd3co in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2006, 06:07 PM
