Thread: Alternator
  1. Alternator
    Lancashire
    when I start my car (115bhp Tdi), I can hear an unhealthy noise coming from the engine compartment, which, after a short while disappeared and the car runs as sweet as a nut, no further noises until I start it up in the morning------at first I was so sure it was the alternator bearings, but if they were going then the noise would be constant ---I checked the belt and tensioner and they seem to be ok, but the belt is the origonal so it may have stretched to it's limits.---the noise by the way stops abruptly, it dosen't sort of lessen gradually.
    Your comments would be welcome
    Rob
  2. re alternator
    Lancashire
    Just found out that the ribbed pulley on the alternator has a small built in clutch mechanism, and this is what's causing the noise--new pulley=£50--
    Rob
    Mar 2007
    I think I am having the same problem, did yours make an unhealthy clicking/knocking sound from the alternator when its starts up or idling with the air con on, but goes when driving?
    I took my golf into a local garage and they took a quick look and said I would need a new Alternator, but as it would be expensive through the garage I have been looking on ebay. Do you think it is a serious problem and should sorted out asap?
  4. alternator
    Lancashire
    It is very hard to describe was type of noise it was, at first I was so sure it was the belt as they can make quite a noise after a while----spray a little silicone on the belt first and try again-----also run a little drop of light oil down behind the pully to lubricate the bearing.
    When a bearing just starts to wear it is usually noisy on start up, and gradually quitens as it heats up------until of course it starts to get worse.
    Always look for the simple---I would change the belt first, inexpensive and easy to do.
    Rob
    Jul 2007
    warrington
    Did you change the pulley, and did this do the trick. Got same problem with my 130 tdi already changed damper tensioner to no avail.
  6. Re: Alternator
    Mar 2007
    I took my golf into the garage for them to change the alternator, but there was no need as the alternator was working fine.
    It was just a case of replacing the pulley that attaches to the alternator as it had started to break due to wear and tear that was causing the noises.
    So now due to the replacement pully, I have a few more pence in my pocket and the golf is a more healthy sounding diesel!
  1. no start due to alternator
    By golf tdi 02 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-06-2007, 05:34 PM
  2. Alternator
    By 150bhpforestboy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-03-2007, 09:55 PM
  3. 03 tdi alternator pulley
    By jeevoe999 in forum New Member Introductions
    Last Post: 26-02-2007, 12:38 AM
  4. alternator
    By gibby45 in forum Passat - Archive Topics
    Last Post: 09-11-2006, 10:08 PM
  5. Alternator casing
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 05:50 PM
