Thread: Steering angle sensor problem
Results 1 to 10 of 14
  1. Steering angle sensor problem
    Hello all
    2002 B6 1.9 tdi Sport
    My ESP and ABS lights came on, and the ******* said there was a fault with the steering angle sensor. I bought VAG-COM and a cable, replaced the sensor and reset the steering centre position following instructions posted here.
    Unfortunately the warning lights persist and I'm now seeing some weird behaviour on VAG-COM.
    Today, when I go into the ABS module I get a fault code "Sensor for steering angle, supply voltage terminal 30 " which won't clear.
    I then went into meas block group 5 and in field 1 the correct steering angle is being reported and it changes in real time when the wheel is turned. However the rotation rate (with the wheel stationary) fluctuates between 0 and 1.5 degs/sec, the brake pressure between 0.65 and 1.3 bar and the transverse acceleration is reported as 0 to 0.9 m/s/s
    When I go back to the fault codes screen there are none shown!!
    When I leave the ABS module and then re-enter it I hear three beeps from the car, and a fault is showing "system function test activated" This code WILL clear.
    When I exit the ABS module I hear a click from under the bonnet.
    Can any experts shed any light on this strange stuff????
    Any advice gratefully received, acted on and reported back here.
  2. Re: Steering angle sensor problem
    S13 - Fuse in relay plate fuse holder 10 A - J527 - Steering column electronics control unit terminal 30
  3. Re: Steering angle sensor problem
    OK thanks I'll check it out tomorrow. What are you suspecting? Dodgy contact, loose fuse, blown fuse?
  4. Re: Steering angle sensor problem
    Angus, Scotland
    I'm sure you've seen this, but when you do the steering angle calibration you need to have the engine running before you move the wheel through its turns. A couple of the guides online don't mention the engine running part!!
    Check for dodgy contacts throughout, it's obviously getting power as it's recording angles and allowing access to it, a good check for something obvious I'm afraid!!
    Let us know how you get on
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  5. Re: Steering angle sensor problem
    Have you checked the steering column electronics control unit for fault codes.I take it the fault was not there before you replaced the steering angle sensor?the pins are very thin and easy damaged.
  6. Re: Steering angle sensor problem
    Angus, Scotland
    Which part did you replace? Was it the Steering control module "8E0 953 549 x" or was it the slip ring?
    Pau
  7. Re: Steering angle sensor problem
    Sep 2007
    Bookham, Surrey
    Quote Originally Posted by Spookytooth View Post
    Hi - I think I have the same problem as you. How easy is it to replace the sensor? How much was the part?
    Have you got to the bottom of the problem yet?
    Ta.
  8. Re: Steering angle sensor problem
    No, I haven't solved the problem. It's going in to the dealer soon. If they find the original steering angle sensor was not faulty, and the fault actually lies elsewhere, I hope they'll refund the cost of the sensor.
    The part is £160 and is easy to fit, although you'll need to search this and other Audi forums to find out how to remove the column shroud and steering wheel. Get the Haynes manual for the B6, as it is now available.
    The part just clips off and on again, but be careful, the clips are fragile. You'll need a working copy of VAG COM and a cable to reset the straight ahead position once the new part is in place. But beware, replacing the part did not solve my problem!
  9. Re: Steering angle sensor problem
    Sep 2007
    Bookham, Surrey
    Very strange. My ABS warning light came on this morning as well as the ESP, then ABS went off when I restarted the engine and stayed off for 25 miles into work (ESP light still on). Then this evening when I came drive home ABS came on when I started the car and stayed on. Then when I got in the car 30 mins later it didn't come on at all. ESP light is now permanently on though. Plan to hold off buying anything until I'm sure what the fault is. Looks like it could be similar to yours...
  10. Re: Steering angle sensor problem
    Sep 2007
    Bookham, Surrey
    Took the steering angle sensor off and cleaned the optics and put WD40 on the contacts. Thoughts I'd solved it as light went off when I took it for a test drive but then came on again after about 5 mins. Looks like either the sensor is toast or the problem is elsewhere. Have attached some useful info here incase anyone else has the same issue.
    Instructions on removing sensor:
    http://www.harddrive.plus.com/Docume...%20Control.pdf
    Note: Its not stated in here but you need the following tools:
    Quote Originally Posted by a8 tech View Post
    [steering wheel nut] 12mm multispline not a torx socket and its 50 nm tighten torque
    Air bag torx 27
    couling torx 8(needs to be about 6 inches long to reach the torx screws in the lower couling) and 2.5 mm alen key for the adjuster arm and 4mm alen key.
    Dash insert 8mm bolts
    For the steering wheel you can use a big torx driver to get the steering wheel off. And the long Torx 8 to get the cowling off - probably have to make your own as I couldn't buy one - thanks to nickynibbles for that tip.
    How to fix a faulty steering angle sensor:
    http://www.tt-forum.co.uk/forum/view...g+angle+sensor
    Pictures of the sensor:
  1. steering angle
    By chris g in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-01-2009, 09:28 PM
  2. Steering Problem
    By Golf_TDI-150 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2008, 08:33 PM
  3. angle eyes
    By papalion in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-09-2007, 03:14 AM
  4. Crank angle sensor
    By febay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-09-2007, 11:35 AM
  5. steering problem
    By golfmark5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-06-2007, 07:53 PM
