Thread: No Brake lights only centre light on
Results 1 to 10 of 11
  1. Exclamation No Brake lights only centre light on
    May 2008
    Can anyone out there help me please...i have an audi a4 tdi on the B5 platform.
    it appears i have no brake lights working on my rear clusters, only the centre light is working...i have checked the bulbs, the fuse ( no 13 )
    i have visually checked the brake light switch. seams ok,
    does anyone have any ideas what may cause this...if the brake light switch was faulty no brake lights would work would they? or is there a way to check it properly...the brake switch has a mulitplug on it with four wires in it, or is there a way to check the relay, ( again i am told it is number 13 )
    any help with this would be greatly appreciated, as my mot is due in the next few weeks, so desperatley need to get this problem fixed...
  2. Re: No Brake lights only centre light on
    2007 Post(s)
    This happens with a faulty brake light switch.
  3. Re: No Brake lights only centre light on
    Aug 2007
    Aberdeen
    I know this might sound stupid but I had this problem, checked the fuse and it was fine, it was driving me mad.....then I checked ALL the fuses and one was blown (which according to my handbook had NOTHING to do with the brakelights) and that fixed it! Check all the fuses just incase your handbook is as stupid as mine! (or wiring is as dodgy I suppose!).
    Tez
    Just sold my MINI, and now own a 1996 A4 Avant 1.9TDI, also proud owner of a 1971 mini
  4. Re: No Brake lights only centre light on
    May 2008
    Thanks for the advice, i will start by checking all the fuses, then if still not working, take it to get the switch checked. Any ideas how much it is for supply and fit of the brake switch?
    One last question...Why isnt the centre brake light affected?
    Anymore advice or tips welcome.
  5. Re: No Brake lights only centre light on
    Quote Originally Posted by chillin_uk View Post
    https://www.vwaudiforum.co.uk/forum/s...highlight=glow
    try this,
    scroll down to tornados post.
    4th cog,--two to go
  6. Re: No Brake lights only centre light on
    erm,but you are already on that thread?
    4th cog,--two to go
  7. Re: No Brake lights only centre light on
    Aug 2007
    Aberdeen
    Good question.....added to the list of unexplainable problems ive had with my Audi since getting it less than a year ago
  8. Re: No Brake lights only centre light on
    Quote Originally Posted by STEWY L View Post
    try this,
    again i show you this thread to which chilly has already posted.
    why don't you read the threads you subcribe to?
    how many times have you got to ask?
    how much time would you like us to waste?
    very kindest regards,
    stewy.
    4th cog,--two to go
  9. Re: No Brake lights only centre light on
    Dec 2007
    Suffolk
    Crasher is probably right the brake light switch has 2 switches inside it 1 for the brake lights and 1 for the abs and top brake light
  10. Re: No Brake lights only centre light on
    Aug 2007
    Aberdeen
    stewy.
    Someone needs to chill!!!
    No1 is forcing you to "waste your time"
    Rant over!
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
  3. Side lights show on high level brake light?
    By joeb in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2009, 10:15 PM
  4. brake lights / brake switch recurring nightmare!
    By stuart40 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:23 PM
  5. Sharan tdi 1997 - No brake lights and Heat coil light flashing
    By hawkz_2002_uk in forum Touran - Sharan - Caravelle
    Last Post: 16-09-2007, 07:20 PM
