Thread: Caliper Retraction Tool
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Caliper Retraction Tool
    Jul 2007
    Co Durham
    Just been to buy a Caliper Retraction tool for doing the pads/discs on my Passat (2001 1.9 TDI) but was asked if it was a left hand or right hand threaded caliper? I didn't realise there was a difference when I have seenb these tools on sale elsewhere?
  2. Re: Caliper Retraction Tool
    they both screw in clockwise.
  3. Re: Caliper Retraction Tool
    Mar 2007
    U-96
    Is this the same as a Brake Piston Rewind Tool, i.e. ;
    Laser 1314: Brake Caliper Piston Re-wind Tool Set
    (BTW, I am not sponsored by Laser Tools )
    TR7
  4. Re: Caliper Retraction Tool
    Quote Originally Posted by WesleyP View Post
    Why? cant you find your long-nose pliers?
  5. Re: Caliper Retraction Tool
    london/ UK
    A big G clamp works just as well and it only costs a fiver at any hardware shop !
  6. Re: Caliper Retraction Tool
    Quote Originally Posted by adamss24 View Post
    whats a g-clamp going to do other than smash the worm inside the caliper ?
    these pistons need screwing back in ,and not forced in using pressure .
    long nose pliers do work if you can push at the same time as turn , i used them to do my calipers but found it really difficult and awkward on the vw caliper , even with the bleed nipple cracked open the piston was really stubborn , if you intend keeping the car for a good few years invest in the proper tools.
  7. Re: Caliper Retraction Tool
    Jun 2006
    UK, Mids
    Just get the proper tool, don't crush them with a G-clamp!
    Remember when using the tool, it is a WINDING tool, not a VICE, it is an easy mistake that many people make and they preload the tool with lots of clamping force and wonder why it is so stiff to turn!
    Audi A8 - 2015 - 3.0TDI
  8. Re: Caliper Retraction Tool
    london/ UK
    Trust me mate, i do a dozen of these every week and i never used another tool other than a G clamp ! In this country every little job needs its own "special" tool and "specialist" !?! What the f*** ? No wonder servicing the car nowadays cost a fortune !
  9. Re: Caliper Retraction Tool
    you are the tool in this thread mate - pistons that need returning to state of origin like those on the passat cannot be simply pushed back , brakes with abs have calipers on the rears as opposed to drum brakes the piston turns on a worm type screw as the hand brake is applied and also self adjusts when the pads wear. what you suggest is incorrect advice to many diy ers out there and will end up costing them a new caliper if they use a g-clamp . ADVISE LIKE THIS IS INCORRECT AND SHOULD WARRANT A FORUM WARNING.
  10. Re: Caliper Retraction Tool
    Jun 2006
    UK, Mids
    I agree, how can you push something threaded back without stripping the threads? That's why I don't go to these garages as they all too often do dumb things like this and act all innocent afterwards. Also, the thread rake of the tool is the same as the thread inside the caliper, otherwise it would bind up.
  1. Rear seatbelt retraction
    By james_tiger_woo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-07-2008, 11:56 AM
  2. O/S/R Caliper
    By rorylion in forum 80 - 90
    Last Post: 28-04-2008, 07:28 PM
  3. '94 Golf Match Caliper
    By Bon in forum Golf MK3 - 1993 - 1999
    Last Post: 23-04-2008, 12:45 PM
  4. A4 caliper windback tool - LH or RH?
    By Jeffmorgan in forum Archive posts
    Last Post: 04-12-2007, 01:03 PM
  5. Caliper Bolts
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-05-2007, 07:55 PM
