Thread: Starting problems
  1. Starting problems
    May 2008
    Hi all, my '98 1.8T passat doesn't want to start after short journeys of 1 or 2 miles. It starts fine when cold or hot. The temp guage works fine, tho I'm not sure if the fans come on a bit early.
    When it won't restart the only way is to leave it for 10mins or to put the accelerator to the floor and keep it there - then pray, otherwise it's flooded for half an hour.
    I'd really appreciate any help on this, cheers.
  2. Re: Starting problems
    Aug 2007
    Mine does the same - But when it does it it also seems to be suffering from a intermittent high idle speed (1800rpm). It's not all the time but any time I really need it
  3. Re: Starting problems
    Mar 2008
    hi guys,
    a similar thing happened to mine the other week,after starting from cold,i didnt give the engine time to warm through [i usually let it idle until the auto choke goes off] then moved it a few metres then switched it off.when i came to restart it,it wouldnt have it,basically i think i flooded it and had to floor the accelerator to start it.
    from then on,i always allow the car to idle until it goes to normal idling revs.
    roy
  4. Re: Starting problems
    May 2008
    Hi Roy, yep that's it, exactly what mine does. Any answers?
    What do folks think about idling the car to warm up? Audi/Vw always say drive straight off on starting and not to idle. Does anyone know why?
  5. Re: Starting problems
    Mar 2008
    bugger what vw says,i would have thouught it makes more sense to let the automatic choke go through its cycle,a bit like after a hard run,you really should idle the car for at least 30 seconds to let the oil cool.
    roy
  1. A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    By nadeem1919 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-08-2011, 06:56 AM
  2. Problems starting !!!!!
    By White_Golf_GTI in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2009, 09:57 PM
  3. 2.0 8V GTI problems starting
    By dainott2105 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2008, 12:57 PM
  4. Vr6 Starting Problems
    By ANDYMANN in forum Archive posts
    Last Post: 28-12-2007, 02:19 PM
  5. Starting Problems
    By vaslam1986 in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 04:20 PM
