Thread: No AM on symphony stereo
Results 11 to 20 of 21
  1. Re: No AM on symphony stereo
    May 2008
    vag com?? do you mean computer with diagnostic software?? Sorry to be a dunce but only just started posting, need to get up to speed with you guys. Also by base unit do you mean what you can see on the roof - or is the base unit hidden away within the roof / lining?
    Appreciate your help (and patience). Sea or course?
  2. Re: No AM on symphony stereo
    May 2007
    knee deep in clunge
    14 Post(s)
    If you follow the aerial antenna down to the bottom you will see it screws into the base.
    This base unit fails on the am reception.
    VAG COM is diagnostic software which helps the user indentify faults.
    union or league
  3. Re: No AM on symphony stereo
    May 2008
    Thanks for the reply.......thought as much.
    I was actually thinking of renewing the "aerial assembly" for a BMW type fin aerial. Thought it might be more robust and less exposed? Can this be done? Any thoughts?
    Union born and bred
  4. Re: No AM on symphony stereo
    Feb 2007
    Quote Originally Posted by a8 tech View Post
    Ok ill help you.
    If you have vag com you can check the coax and aerial base in measured value blocks.
    If not its 75% roof aerial base unit defectie as the am side fails whilst the fm is ok.
    I fish therefore im a lazy sports man
    a8tech ,
    Could explain in a little more detail how to check measured value blocks for the aerial please.I have genuine vag com but am fairly new to the game.
    djl
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  5. Re: No AM on symphony stereo
    May 2007
    knee deep in clunge
    14 Post(s)
    Look at measured value block 3 componant,this will indicate if the aerial is open circuit or short to earth.
    I tend to find the block indicates short to earth as the coax cable breaks but the base (in the roof where the antenna screws in)is a common failure.
    ; VAG-COM Label File
    ; Audi A4 (8D)
    ; Component: R - Radio (#56) Generation I
    ; P/N: 8D0-035-1??-???
    ; includes measuring blocks, adaptation and coding
    ; This file is part of a redirection package,
    ; make sure you have all of the following files.
    ; 8D-56.LBL
    ; 8D0-035-1xx-56.LBL
    ; created on 25/Apr/2007 by Sebastian Stange (Sebastian@Ross-Tech.com)
    ; last modification: 25/Apr/2007
    ; requires VAG-COM 701.0 or newer
    ; measuring blocks
    001,0,General
    001,1,Speed Signal,recognized
    001,2,Supply Voltage,(Terminal 30)
    001,3,Illumination,(Terminal 58d)
    001,4,Status,S-Contact,Range: ON/OFF
    002,0,Speaker/Line-Out
    002,1,Location/Type
    002,2,Status
    002,3,Location/Type
    002,4,Status
    003,0,Antenna
    003,1,Antenna Type
    003,2,Component
    003,3,Status
    004,0,General
    004,1,Amplifier,Output,0 = OK\n1 = Short to Ground
    004,3,Telephone
    004,4,Telephone,Mute Status,Range: ON/OFF
    005,0,Communication Status CD-Changer (R41)
    005,1,CD-Changer (R41)
    005,2,Status
    006,0,External Display
    006,1,External Display
    006,2,Status,,Specification: OK/n.OK
    007,0,Steering Wheel Control
    007,1,Steering Wheel,Buttons
    ; coding
    C00,Radio (R) Coding
    C01,00?xx: Speakers
    C02,0 = Sound System (No passive Speakers)
    C03,1 = 1 passive Speaker (Front Left for Bose Sound System with Telephone)
    C04,2 = 2 passive Speakers (Front) and 2 active Speakers (Rear)
    C05,5 = 2 passive Speakers (Front) and no active Speakers (Rear)
    C06,00x?x: Sound System Correction
    C07,0 = No Sound System (No Correction)
    C08,1 = Sound System (Bose)
    C09,00xx?: Configuration
    C10,+1 = Active/Remote Supplied Antenna
    C11,+2 = CD-Changer
    C12,+4 = Secondary Display (Board Computer/Navigation)
  6. Re: No AM on symphony stereo
    Feb 2007
    Thanks for the reply.Incidentally i have an a6 allroad c5 chassis.I checked group 3 in measured blocks and everything seems fine.
    I also gained access to the diversity box under the headlining to make sure there was supply voltage which there is (12v).
    I also checked the main coax cable coming from radio by inserting a very thin wire into it,hey presto i got am loud and clear.
    I removed the aerial base and it appears the the cable is slightly chaffed and the wires underneath are visible.Would that affect the operation?
    So am i right in assuming that it's either the diversity box or the aerial itself?
    Thanks again..
    djl
  7. Re: No AM on symphony stereo
    #17
    May 2007
    knee deep in clunge
    14 Post(s)
    measured value checks DC supply but not the the frequency so check the continuity.Also you can check the reception by pressing the station 1 button when you turn the radio on until the test mode comes on then press tone three times.
    The last two digits of the lower line show the dbuv level.(concert and chorus)
    For symphony press stsion button 1 when turning on until the test mode comes on
  8. Re: No AM on symphony stereo
    #18
    Feb 2007
    My better half has a 9N polo and i'm thinking maybe it would be possible to slave in the aerial off that before i plunge into buying another one from Audi.
    No doubt the connectors will be different but it's worth a try i guess.
    Thanks again for your help,very much appreciated.
    djl
  9. Re: No AM on symphony stereo
    #19
    Feb 2007
    For symphony press station button 1 when turning on until the test mode comes on
    I've tried the test mode,didn't know that existed..,and i get the following on the screen..
    AM1 693
    693 07 00 00 00
    Means nothing to me...
    I wasn't sure how to check the continuity of the aerial with a multimeter but what i did do was check between the bit where the aerial screws in and the outer section of plug where it connects to div box but i didn't get continuity.
  10. Re: No AM on symphony stereo
    #20
    May 2007
    knee deep in clunge
    14 Post(s)
    I tried mine on the way home.
    am talksport 693 07 00 00 50 i was getting xxx xx xx xx 42 to xxx xx xx xx 50
    My am signal is fine so if your getting 693 07 00 00 00 you have no reception.
    Swap the base from the polo if ot fits or bypass the div box if possible.
    I have all the different coax attatchments and a spare base to do this as its sometimes the only way to eliminate and trace the fault.
    When using the service mode try driving the car and see if the signal changes to eliminate outside interferance.Regards A8
  1. Help - Removal Of Symphony Stereo
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2008, 08:30 PM
  2. Symphony Stereo Code & Radio Fault
    By SimonVindec in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2008, 02:42 AM
  3. Audi Avant A4 Symphony Stereo Radio failure
    By SimonVindec in forum New Member Introductions
    Last Post: 19-03-2008, 02:15 AM
  4. A4 Symphony Stereo
    By JRW1979 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-10-2007, 02:00 PM
  5. Audi A3 symphony II stereo
    By boxhave in forum Audi A3 - Archive Topics
    Last Post: 13-04-2007, 10:34 AM
