Thread: Audi A3 1.8 8 T Fuel Trim DTC code & loss of power
  1. Audi A3 1.8 8 T Fuel Trim DTC code & loss of power
    Hello and Happy New Year to all forum members, please help if you can:
    I have a A3 1.8 T Sport (x) Registration (2000). It is the 150 BHP model. Recently it has the following problems:
    - At speed on motorway noticeable loss of power in that the throttle is no longer as responsive as it should be. Car then has loss of power problems in just about every gear - some lurching.
    - Fails to idle at a consistent level of revs. Revs fluctuate and fall low enough to bring the car close to stalling.
    - Loss of power will eventually continue until the point of breakdown recovery. Car is recovered and DTC fault codes reset and car returns to normal capability.
    - Before long (perhaps 150 miles) cycle starts again
    - The only warning light on the dash relates to the yellow warning symbol for brake light failure. The brakes lights work without a problem.
    - The DTC codes are P0170, P1114 and P1128 - All of these codes appears to relate to the Fuel Trim Add Air Bank 1 System.
    PO170 = Fuel Trim Bank 1 Malfunction
    P1114 = Bank 1 Sensor 2 Internal Resistant too High
    P1128 = Long Term Fuel Trim mult. Bank 1 System too Lean
    - However, I wonder whether, if I have a faulty blake light switch this is causing the ECU (computer) to believe there to be problems with the fuel trim and/or is causing the car to revert to limp home mode?
    - The emissions from the car are as they should be. There is as I understand it 2 oxygen/lambda sensors - one before the cat and one after. The 1st lambda sensor has been checked and is fine, could the fuel trim problems be down to the second lambda sensor?
    - And/or might this be a problem with the hoses regulating fuel pressure and turbo pressure and a possible air leak?
    If anybody can shed any light on this conundrum I would be so grateful.
    Paignton, Devon
    Have you checked the MAF which are prone to failure on the 1.8T and could put the car into limp home mode ??
    Coil packs are another big cause of power failure too,even if one has gone down it will affect the engine running correctly...
  3. thanks for your help
    I am suspicious of MAF because when I disconnect it car runs a lot more smoothly. Coil pack has gone in past and replaced free by audi as a known fault.
    Will sort MAF this w end and let u know how i get on.
  4. Question Re: Audi A3 1.8 8 T Fuel Trim DTC code & loss of power
    Hi I am new to this forum but have a similar problem with my Audi A4 1.8T Avant. Sorry I am not too mechanically minded what is a MAF...if anyone can help it would be appreciated. Cheers
  5. Re: Audi A3 1.8 8 T Fuel Trim DTC code & loss of power
    High Wycombe, Bucks
    MAF = Mass Airflow Sensor.
    Here is a good link that explaines what it is. It does apply to a Scorpio but it gives you an idea.
    http://www.fordscorpio.co.uk/cleanmaf.htm
    Mick
  6. Re: Audi A3 1.8 8 T Fuel Trim DTC code & loss of power
    High Wycombe, Bucks
    And here is a link to an Audi tech Bulletin, it's not for the A3 but again useful.
    http://www.wak-tt.com/vagcom/maftecdoc.pdf
    Mick
  1. Audi A4 tdi loss of power
    By siddlem in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2007, 09:07 PM
  2. audi a6 power steering fluid loss
    By nigepet in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-01-2007, 09:32 PM
  3. 1995 Audi A4 TDI 90BHP Smoking And Power Loss
    By cstevens99 in forum Audi A4 - Archive Topics
    Last Post: 19-11-2006, 10:00 PM
  4. audi 80 electrical power loss
    By draddog60 in forum 80 - 90
    Last Post: 15-10-2006, 03:08 PM
  5. audi 80 loss of power
    By gabby in forum 80 - 90
    Last Post: 11-01-2006, 11:42 PM
