Thread: Headlamp Warning sounder
  1. Headlamp Warning sounder
    May 2006
    South East England
    I have just noticed...after leaving my A6 2002 1.9tdi headlights on overnight...that the warning noise that comes on when you get out of the car with your lights on has dissapeared...i assume its the same thing that sounds on engine check at start up as thats also stopped...? any ideas where this part is located....which fuse it uses...so i can check...?
  2. Red face Headlamp Warning Sounder A6
    Nov 2006
    Southampton
    I have a 2001 A6 which has had the same symptoms, this proved to be a faulty microswitch which is fitted to the drivers' door latch.
    When you first open the door, not only should your interior light come on , but the display for the odometer and the clock should illuminate if any of these are missing then it's a good bet it's the microswitch in the drivers door.
    It's also this switch which tells the system that you've opened your drivers door with the lights on, so it may be this switch thats at fault you of course have to have the key out of the ignition first.
    Hope this helps
    Gazza57
    Dec 2006
    thats right... try the aboe and report back
    RicKT
    May 2006
    South East England
    only thing is...that the interior lights etc work fine on opening the drivers door...!
    the engine check routine and low fuel level alarms have dissapeard...you normally get an annoying beep when the fuel gets low and when you first place the key the ignition a turn on (not start)...this has gone as well as the alarm noise for the headlights on door open warning...!
    so i'm not sure its door microswitch...so i really wanted to locate and check 'warning alarm'...!?
  5. Question
    Nov 2006
    I am having a problem withe the buzzer for headlamps when left on and the lights under all but one door are out when opened . Is this a connected problem?
    london/ UK
    Quote Originally Posted by cronic View Post
    The"buzzer" its soldered on the instruments printed circuit board and to access it, the clocks will need removing. I suggest have someone with a vag com scan for diagnostic/fault codes, as something its wrong there ! Going to dealer will result in replacing the entire dash instruments and they will need codding,because the clocks contains the immobiliser and needs to be matched to your car's engine and keys.
    May 2006
    South East England
    Quote Originally Posted by adamss24 View Post
    Oh happy dayz...! i had a distinct feeling this would result in an expensive problem to fix...!!
    i have a non-audi warranty which will cover parts but the labour hourly rate at an audi dealer will be far more than the £40 per Hour cover i have with olympic...! i have since noticed that the rev counter is doing some funny shizz on start up...seems to be o.k after a couple of seconds...!
    i hope the A6 2002 model years do not have the same problems associated with the cluster (electrical) issues found on the TT's...? those TT's made it onto BBC's watch dog....does anybody know if the A6 now has similar cluster warranty issue coverage..???
  1. Mk 4 Gti Headlamp Bulbs
    By vespapete in forum Archive posts
    Last Post: 20-04-2007, 07:02 PM
  2. Golf Mk4- Headlamp Wash
    By bluenose in forum Golf MK4 - 1999 - 2004
    Last Post: 14-03-2007, 09:27 PM
  3. Audi A6 Headlamp Adjustment
    By Kirky in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-01-2007, 11:33 AM
  4. Changing headlamp bulbs in 04 Passat TDI
    By srobins in forum Passat - Archive Topics
    Last Post: 12-01-2007, 02:47 PM
  5. Headlamp adjuster stickers on Golf TDi
    By stuart in forum Archive posts
    Last Post: 13-12-2005, 09:47 PM
