Thread: am i being a numpty or is it just not working?
  1. Post am i being a numpty or is it just not working?
    Luton, United Kingdom
    Hey new to the vag-com thingy..... but really want to do the basic adaptations, anti-hijack on/auto unlock on, horn beep on unlock/lock.............
    im getting to the correct part in the vag-com through the "central conv"......... change the options from a "0" to a "1" to turn it on...... click save.... says are u sure..... obviously i am......
    then when i look again.... its back to default
    am i a numpty am i missing something??
    CHEERS!!!
  2. Re: am i being a numpty or is it just not working?
    are you testng it before you save ? also it it a registared version ?
    from what i can remember i had to test it before i could save ( version 409.1 ) and i think it has to be a registared version to save to the flash memory
    1.8T AUQ head standard engine. Newsouth performance Boost, Oil pressure and Temperature gauges, 6 spoke TT alloys and A8 interior light.
    Next engine
  3. Re: am i being a numpty or is it just not working?
    it seems it does an auto test (the test button is greyed out) and yes its a registared version says in the "about" button "fully registered / activated"
    btw this is on a VW Bora 2002 "1J" motor.....
  4. Re: am i being a numpty or is it just not working?
    and i thought this forum would help......
  5. Re: am i being a numpty or is it just not working?
    Jun 2007
    A, A
    Anti Hijack
    46 – Central convenience
    10 - Adaptation
    Channel 03 Auto Lock (auto locks car after 10mph)
    Channel 04 Auto Unlock (unlock the car when u take the key out)
    Single Door Unlock
    46 – Cent Convenience
    07 - Recode
    The single door unlock give an even number i.e. 00064. To make all the doors unlock with one press, just add 1 i.e. 00065
    Lock / unlock beeps
    10 - Adaption
    Channel 05 Unlock, horn sounds (not a horn, more like a beep when u unlock)
    Channel 06 Lock, horn sounds (same as above only other way around)
    Channel 07 Unlock, turn signals flash (easy)
    Channel 08 Lock, turn signals flash (easy)
    Just another B7 Estate
  6. Re: am i being a numpty or is it just not working?
    yer i know how to do it and where, but it seems not to save the settings i set...... any idea why?
  1. Question Air Con not working
    By dave07973 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-05-2011, 07:26 PM
  2. Sat Nav not working.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-04-2011, 02:19 PM
  3. Cigarette lighter not working - Engine & Oil temp gauges not working.
    By Shagger7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 12:10 PM
  4. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
  5. s3 air con not working.
    By chaseyersell in forum Audi A3 - Archive Topics
    Last Post: 06-06-2007, 10:13 AM
