Thread: 2.0 TDi sport rattling noise
  1. 2.0 TDi sport rattling noise
    Hi, don't know if anyone has any thoughts about a noise that I've just noticed. My Golf has 1400 miles on it and I noticed a rattling noise at very low speed in an indoor car park today. It sounds a bit like there's a tin can rattling along underneath the car. It doesn't seem to make the noise at road speeds. I have noticed it a couple of times as I come to a stop and pull away at roundabouts. I've had a look underneath but nothing is loose or appears to be out of place. I'm going to get it to the dealers at some point next week. Other than this noise the car has been brilliant. Thanks for reading this.
  2. Re: 2.0 TDi sport rattling noise
    Chester-le-Street, United Kingdom
    i don't know what your exhaust would be like,but on earlier ones thier was an exhaust
    bracket just to the passenger side of the tunnel that cracked and rattled. easy to weld,
    although yours will be under warranty so shouldn't cost you at all.
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: 2.0 TDi sport rattling noise
    I noticed that on my golf aswell. Dont know what it is please post update if you find out
  4. Re: 2.0 TDi sport rattling noise
    Newcastle-upon-Tyne
    Hi, You might want to check the heat shield at the back of the engine. Looking from the engine bay, look at the back of the engine, way down below the bulkhead, and you can just see an aluminium plate. Mine was vibrating against the steering column at low revs, making a noise just as you describe. Check to see if it is rubbing against anything, and bend it out of the way. Hope this helps.
  5. Re: 2.0 TDi sport rattling noise
    I just checked with the service dept. at main dealer. Technician thought it was probably a stone caught behind a brake disc. Sounds reasonable as I have stones on my drive! Also the noise is a bit more 'ringy' as in bell. We'll see how it goes for now. Thanks for the replies.
  6. Re: 2.0 TDi sport rattling noise
    Newcastle-upon-Tyne
    You may want to check the splash guards fitted to the front disc brakes. I have been trying to find the source of this rattling for a while, and just by chance, I found these guards vibrate and rattle at low revs. Try pushing the guards back away from the disc and see if the noise goes away, or reduces. I did this and the rattling did get less. I need to have a proper look at this and come up with a permanent fix. Hope this helps.
  1. Rattling Noise
    By markyg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2008, 08:14 PM
  2. rattling noise after engine start
    By ebyrahim in forum Golf MK5 - 2004 - 2009
    Last Post: 22-04-2008, 05:07 PM
  3. Rattling Noise only on load
    By TeDs in forum Bora - 1998 - 2005
    Last Post: 12-04-2008, 01:01 AM
  4. rattling noise at 2800 revs (ish)
    By apple mike in forum Golf MK2 - 1984 - 1992
    Last Post: 03-11-2007, 10:58 PM
  5. rattling noise when start up
    By 1staudiA3 in forum Audi A3 - Archive Topics
    Last Post: 07-10-2007, 02:04 PM
