Thread: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
  1. Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    Hi all
    Im getting a pretty distinctive tapping sound coming the engine - sounds like the top of the engine. Tappets, etc area. Increases as engine revs...
    Anyone had this issue before on their bora/golf? Any ideas on fixes, costs, etc? Maybe its normal? Its not that bad when idling, but as you rev its more obvious.
    zimbora
  2. Re: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    133 Post(s)
    1986 Post(s)
    Certainly sounds like tappets but it is not a problem I see often with this engine. I would try an oil and filter change first. If that doesn’t cure it, an oil pressure test would be the next step. I have never seen cam wear on one of these engines but I have known the lifters to fail and that is quite a lot of work to do as it includes replacing the cam belt as well when you should also replace the water pump.
  3. Re: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    Thanks for the reply Crasher.
    I just changed the oil & filter today - thats when I really noticed the tapping noise. I hope it improves.
    How does one do an oil pressure test? Sounds like a garage job....
  4. Re: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    By the way, mileage is 76k...
  5. Re: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    133 Post(s)
    1986 Post(s)
    You have just pulled some air up into the hydraulic tappets, it will go away.
  6. Re: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    Thanks again Crasher,
    I have driven about 90 miles today and its still doing the same. If it is air in the system, do you think it would have gone away by now?
  7. Re: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    133 Post(s)
    1986 Post(s)
    I would have thought so, yes.
  8. Re: Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    I think I might visit a vw place tomorrow and see what they reckon. Hope its not serious......
  1. v5 bora ticking noise from engine
    By sigarv in forum Bora - 1998 - 2005
    Last Post: 17-04-2008, 01:03 AM
  2. A3 Ticking Sound
    By RichKi in forum Audi A3 - Archive Topics
    Last Post: 15-02-2008, 06:35 PM
  3. Bora 1.6 Tapping / Ticking
    By dph1978 in forum Bora - 1998 - 2005
    Last Post: 14-02-2008, 09:32 PM
  4. Beetle 2.3 v5 engine tapping/ticking
    By squiresv5 in forum Beetle 2000-
    Last Post: 15-12-2007, 04:45 AM
  5. Slight Tapping, whirring sound
    By Whitie in forum Archive posts
    Last Post: 10-02-2005, 10:30 AM
