Thread: Passenger Airbag Deactivation Fault
  1. Passenger Airbag Deactivation Fault
    May 2007
    I've recently replaced both seatbelt tensioners, driver airbag and passenger airbag, had my airbag modules crash data erased, but the airbag light keeps coming on (even when I reset it with my CAN OBD reader). When I erase it, the light goes off, but then comes bck on a second later. I get a fault code "01578" which means "Airbag Deactivation Warning Lamp: Passender Side (K145)".
    I can activate and deactivate the passenger airbag from within the glovebox, but this doesn't seem to be the issues. I'm wondering when I fitted the airbag whether there's something I should have done with the new airbag like pull a pin out or enable it somehow? I literaly just plugged the new one straight in. Did I miss something?
  2. Re: Passenger Airbag Deactivation Fault
    Hi Your code means one of the following faults Open circuit
    Short to earth or short to positive
    Warning lamp -K145 defective
    Control unit for airbag -J234 defective
  3. Re: Passenger Airbag Deactivation Fault
    May 2007
    All sorted. I'd not connected the 2-pin wire that plugs underneath the front of the radio / navigation unit where the passenger airbag deactivation light was.
  1. Passenger airbag
    By weepiglet in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-02-2008, 11:37 AM
  2. Removing Passenger Airbag
    By Nebooaw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2007, 12:58 PM
  3. 2001 Passat Passenger Airbag
    By happygu73 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-05-2007, 08:03 AM
  4. Passenger Airbag
    By Samcat in forum Passat - Archive Topics
    Last Post: 15-11-2006, 10:03 AM
  5. A4 Avant - front passenger airbag deactivation
    By marklucas in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-07-2006, 07:37 PM
