Thread: Locked out of my Audi A4
  1. Locked out of my Audi A4
    Dec 2006
    I purchased a 2001 A4 TDI recently. I drove it home but didn't use it for a while and the battery went flat.
    I can't get into it now as the remote won't work. The key turns in the driver's door lock but the lock doesn't operate.
    I can get into the boot and even attempted to attach a battery charger to the wire attached to the boot light to see if I could charge the battey that way -- to no avail.
    Is there a way to open the door or the bonnet from the outside?
    I may have to resort to breaking a window but that is a bit drastic.
    Thanks,
    Steve
    Dec 2006
    Have you manage to get this sorted now??
    if you insert the key and turn it, it will open as its a manual over ride, you have to turn it to the max to open the drivers door only.
    let us know how you have got on.
    RickT
  3. Still locked out
    Dec 2006
    Hi Rick,
    Thanks for the reply.
    I am still locked out.
    I have tried the key and it turns in the lock perfectly but the door doesn't unlock.
    The lock seems to be a slightly loose in the door so I suspect that it isn't operating manually.
    The boot operates perfectly with the key.
    Thanks,
    Steve
    Oct 2006
    I disconnected my battery at weekend and had to reprogram the fob to the car.
    I found that the lock operates opposite to other locks - to lock turn anti CW to lock and CW to unlock (I think, anyway when I did it, it seemed the wrong way round).
    Open door then press unlock on fob, turn ignition on, then off. It now should work. If you're not quick in switching on ign. the alarm will sound, but will stop when ign. is turned on.
    Presumming you have a saloon, car the rear seats be folded down from the boot - is the release catch in the boot? If you can fold them down maybe try and climb through to open the bonnet?
  1. help!! Keys locked in car
    By Bozmeister in forum Passat - Archive Topics
    Last Post: 20-11-2007, 01:53 PM
  2. my door just stays locked
    By diljaa in forum Golf MK4 - 1999 - 2004
    Last Post: 05-12-2006, 05:48 PM
  3. Locked door woes, how to open it to repair it?
    By sensible in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-11-2006, 10:33 PM
  4. Locked out my boot
    By shuglaird@msn.com in forum Archive posts
    Last Post: 20-07-2006, 04:41 PM
  5. Passat boot issue - locked out help!
    By KingConker in forum Passat - Archive Topics
    Last Post: 06-02-2006, 11:00 AM
