Thread: Golf MK3 GTI(8V) Electric Window Fuse/Relay Search
  1. Golf MK3 GTI(8V) Electric Window Fuse/Relay Search
    May 2008
    Hello everyone i'm trying to locate fuses/relays that control power windows on my 3door mk3 gti. can seems to find it. my passenger window is out of action so i want to look @ the simplest things first....tnx in advance
  2. Re: Golf MK3 GTI(8V) Electric Window Fuse/Relay Search
    Jan 2008
    hi ya bit new at this but both my windows packed up on my MK3 8v gti 3dr i thought it was the motors or relay but i found it to be as simple as the connector to the motor it self, located at the lower part of the door (looks like a scart socket for the TV) ive taken it off brushed it clean put it back on and taped it up so it shouldn't move failing that fuses and relays i think are located behind the dash driver side nearest the door above the pedals
    hope this helps
  3. Re: Golf MK3 GTI(8V) Electric Window Fuse/Relay Search
    May 2008
    tnx for your reply but mine turned out to be a motor problem so i replaced it & window works now
  1. mk3 golf electric window problems
    By Dan IOW in forum Golf MK3 - 1993 - 1999
    Last Post: 24-09-2015, 09:27 PM
  2. Electric window fault, maybe the relay?
    By Ebenezer Scroog in forum Golf MK4 - 1999 - 2004
    Last Post: 16-04-2008, 06:12 PM
  3. Mk 4 golf Electric Window
    By littlemissmagic in forum Golf MK4 - 1999 - 2004
    Last Post: 25-03-2008, 08:28 PM
  4. electric window fuse??
    By stuk2000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-08-2007, 04:33 PM
  5. golf mk3 electric window
    By hogiapesda in forum Golf MK3 - 1993 - 1999
    Last Post: 23-07-2007, 10:16 PM
