Thread: Failing Electrics-Wash/wipe-HRW & Heater
  1. Question Failing Electrics-Wash/wipe-HRW & Heater
    May 2008
    My 1989 Mk2 Jetta has just started developing electrical gremlins. All the wiper switch functions the Heated Rear Window and Heater blower (all Positions have stopped). The heater blower rheostat and motor were changed 2 years ago. They heve worked faultlessly until now. All the fuses are intact and each of the problem circuits are fused separately. The Golf used to have some problems with the fusebox.
    Is this likely to be the same?
    If so. Can the fusebox be repaired?
  2. Re: Failing Electrics-Wash/wipe-HRW & Heater
    134 Post(s)
    2022 Post(s)
    The X circuit has shut down and will be either the X relay or the ignition switch. Is your hazard switch on the dash or on top of the steering column? The only Golf fuse boxes that regularly failed were those on pre 83 Golf 1’s.
  3. Re: Failing Electrics-Wash/wipe-HRW & Heater
    May 2008
    Thanks I can now see from the diagram the "link" 'X'.
    Which is the 'X' relay my manual does not identify it!
    The hazard switch is on the top of the steering column.
    How do identify the 'X' circuit wiring at the ignition switch, Do I look for 12v feed with ignition on and if none this is the circuit at fault. Is it possible to check the switch or do I just order a relacement.
    Can you tell I know little about vehicle electrics, even less about the diagrams in the manual!
  4. Re: Failing Electrics-Wash/wipe-HRW & Heater
    134 Post(s)
    2022 Post(s)
    By the hazard switch being on top of the steering column I can tell you have the later type of fuse box so the X relay is at position 4 (upper row of main relays, fourth from the left) and it has the number 18 on top and from VW is now VAG part number 7M0 951 253 A and costs about £13. The X relay is controlled by the ignition switch from position X (funnily enough) on the ignition switch and this is marked on the switch and plug and the wire colour is black/yellow. Thinking about it, if the headlights are not working, it will be the ignition switch and not the really as the lights are powered from the X line switch command, not from the relay. Only buy a new switch from a VW dealer, do not buy them pattern as they are very unreliable.
  5. Re: Failing Electrics-Wash/wipe-HRW & Heater
    May 2008
    Thanks............ The headlamps are working so I have ordered a relay for tomorrow Tuesday. Will post result when fitted. It is good to know someone out there is willing to spend time and help.
  6. Re: Failing Electrics-Wash/wipe-HRW & Heater
    May 2008
    New relay '100' part number as described £10.35 +VAT. Job done, very satisfied. Wish I could read the diagrams properly. Still It might help if I understood the vehicle electrics a bit!
  1. Rear Wash Wipe A4 Avant
    By pg20 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-02-2010, 10:42 PM
  2. Audi A4 Avant Rear Wash Wipe
    By dava in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2008, 10:00 PM
  3. Rear Wash Wipe Tubing
    By s4k1b in forum Golf MK4 - 1999 - 2004
    Last Post: 12-02-2008, 05:09 PM
  4. Rear Wash Wipe delay
    By PopDorset in forum Touran - Sharan - Caravelle
    Last Post: 27-10-2006, 09:29 PM
  5. rear wash wipe trouble
    By gareth in forum Passat - Archive Topics
    Last Post: 08-09-2006, 02:05 PM
