Thread: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
Results 1 to 10 of 17
  1. Angry Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    Hello
    I have a '97 long wheelbase caravelle VR6, which is great in every respect except for the automatic gearbox. I had the gearbox rebuilt which cost a lot soon after buying the van, and it went back a few times and although better and perfectly driveable most of the time afterwards, it was never quite right. Now just 3 years later it has gone again, and needs another rebuild. Reluctant to go through the same again, I would prefer to change the gearbox altogether this time.
    Ideally I would love to convert to manual (I wanted a manual originally but settled for auto after 18 months searching (i need the long wheelbase, which combined with VR6 and manual is virtually non-existent!) Can this only be done with a manual donor vehicle? If so this would be even harder to find than a running VR6 manual??
    Is it possible to use the VR6 sharan's auto gearbox? They are so much cheaper and more available, I can buy a whole VR6 sharan in good condition with MOt and tax for less than the cost of a gearbox rebuild, just to put costs into perspective - so if that gearbox can be used it will be a lot cheaper and easier to find.
    Better still, can a manual gearbox be taken from another VR6 sharan, golf, corrado etc, or can a non-VR6 transporter/caravelle manual gearbox be fitted?
    Any help will really be appreciated - many thanks
  2. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    Dec 2006
    Manchester
    Have you got the gearbox code???
    Welcome to the forum! Unfortunatly, i can't help, but I think i know just the man to steer you in the right direction.....
    In the meantime, if you could post you engine code and gearbox code. This will help determine what (if anything) can be done.
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    134 Post(s)
    2016 Post(s)
    PM sent.
  4. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    Thanks for asking, the engine no. is AE5006851, Reg No. is S502JLM, where would I find the gearbox code?
  5. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    134 Post(s)
    2016 Post(s)
    Your vehicle has an AES engine (there is an error on your log book) and the gearbox code is DNE and is of the 01P series. By the fact the vehicle was registered 9/98 and built 04/97 I presume it is an import and left hand drive. The Sharan 099 series box is similar to the 01P used in yours but I think there would be problems adapting it and they are pretty unreliable anyway. I would recommend a VAG exchange box but these are a rather stiff £2.5K. Converting to manual could be done but it is a hell of a task and you would need to find a donor vehicle with a manual box (AFL is one suitable code) of the 02G series and these were only used on the T4 VR6.
  6. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    Thanks - the VW exchange box is much more money still than the gearbox rebuild, so really would like to investigate other ways around it. Any idea how much work/cost the sharan auto, and the manual conversion might involve?
    The Van is a right hand drive. It was bought new from a UK main VW dealer in '98 although it had been shipped to Gibraltar, where it was destined for export to Singapore, but instead after hanging around in Gibraltar, it was shipped straight to the London main dealer where it was sold from!
    It is a long wheelbase which I need so not easy to just find another. I really hope I can sort this out. All help much appreciated.
  7. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    Hello
    Does anybody know if the DNE 01P auto gearbox, (in the Caravelle VR6) was used anywhere else at all? Looking for replacement gearbox but so few VR6 caravelles about. Alternatively would any other gearbox work in my VR6 Caravelle, perhaps another transporter engine's gearbox, or a golf etc VR6 auto gearbox?
  8. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    134 Post(s)
    2016 Post(s)
    97 to 99 Transporter VR6 only, super rare and £2.5K from VW although the later EQE may be compatible.
  9. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    could any other gearboxes be adapted to fit?
  10. Re: Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    134 Post(s)
    2016 Post(s)
    They have to be from a VR6 T4 as the software is specifically calibrated to the engines ECU and the bolt pattern to the block is specific to the VR6. There are also DNF and EQH boxes that it may be possible to adapt.
  1. Woudl you recommend AUTO over Manual?
    By peterwatkins99 in forum Bora - 1998 - 2005
    Last Post: 26-06-2008, 04:35 PM
  2. Would an engine from A4 1.8 auto be suitable for a manual?
    By pops20vq in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-03-2008, 01:36 PM
  3. engine change auto box to manual box
    By socrates1743 in forum Chat - Anything with wheels
    Last Post: 29-02-2008, 06:32 PM
  4. Tdi Auto Or Manual ?
    By ajc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2007, 12:07 PM
  5. A4 2.5TDI 180 Sport Quattro: Manual or Auto
    By naz11 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-09-2007, 10:16 AM
