Thread: gt tdi shocks and springs....which ones any good??
Results 1 to 10 of 12
  1. gt tdi shocks and springs....which ones any good??
    Mar 2007
    hello peeps.....i was wondering if anyone had any experience with shocks and spring kits off e-bay??........the coil-overs look good value but are they any good??...i dont want to necessarily want to lower it by too much if any but was wanting to replace shocks and springs as mine feel a bit wooly!!
  2. Re: gt tdi shocks and springs....which ones any good??
    134 Post(s)
    2025 Post(s)
    Remember a coil over kit, no mater how cheap or expensive, can be pretty harsh and difficult to live with on a daily driver.
    I sell Vogtland, Weitec, Koni and Eibach.
  3. Re: gt tdi shocks and springs....which ones any good??
    Mar 2007
    hi..mmmm....taking that into consideration, I mind just go for replacement parts then. cheers
  4. Re: gt tdi shocks and springs....which ones any good??
    134 Post(s)
    2025 Post(s)
    Don’t let just me put you off, I am getting old and boring! I have coil over Weitec kits on my Golf 1 and Golf 2 GTI’s, a conventional 20-mm lowering kit on my wife’s golf 2 and standard suspension on my daily driver Octavia VRS. Even my 72 Beetle is lowered. You may want to consider a conventional lowering kit but don’t get sucked into the fleaBay cheap rubbish, you need to be spending around £250 to £280 on a good kit like the Vogtland Sport or Weitec GT.
  5. Re: gt tdi shocks and springs....which ones any good??
    Mar 2007
    cheers mate.....i,ll bear that in mind....the thing is, the wife uses it quite a bit too, and i don,t want a load of grief off her if its too harsh a ride. Also I tow a caravan and dont want to loose too much height (although I did make the towbar myself and can mod it to suit....Its my job, by the way)
    cheers again...
  6. Re: gt tdi shocks and springs....which ones any good??
    I'm considering the same thing - lowering the car. I'm not a boy racer, but really like the lowered look of the mk4.
    I have a 2000 gt tdi (85kw) 5 door, and have noticed that the car sits higher on the rear than it does on the front.
    The only springs I've seen that would level this are the KW, the Eibach only do the same lowering all round (that i've seen). But want the best i can afford. Do i really want the shocks too?? only want the look and bit more body control, not a hard ride. very confused.
    sorry for hijacking.
  7. Re: gt tdi shocks and springs....which ones any good??
    134 Post(s)
    2025 Post(s)
    Don't trust the listed drops, they are only a guide. The Eibach set drops the car flat.
  8. Re: gt tdi shocks and springs....which ones any good??
    Cool,
    because I was wanting the Eibach, read alot of good things - from your good self and others, about them.
    Eibach it is. Thats a wee job for the summer then - i'm a teacher, so gona have a bit of free time coming up
  9. Re: gt tdi shocks and springs....which ones any good??
    134 Post(s)
    2025 Post(s)
    If you do this, order some shortened dampers (Alko are my favourite) to go with them and fit shortened bump stops front and rear if your car doesn’t already have them.
  10. Re: gt tdi shocks and springs....which ones any good??
    Thanks crasher. There's alot to think about, more than would seem obvious.
    Do you supply that kit to post out? or can you recomend a place to get it? dont know if I'm alowed to ask, so appologies.
    Thanks again.
  1. '98 A4 shocks or springs (or both)?
    By pelerin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-03-2008, 11:45 AM
  2. shocks
    By vwray in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2008, 11:22 PM
  3. New shocks / springs
    By msond in forum 80 - 90
    Last Post: 08-06-2007, 08:47 PM
  4. Shocks n Springs
    By Jigs in forum Passat - Archive Topics
    Last Post: 19-03-2007, 03:24 PM
  5. Is Changeing the Springs a good idea???
    By bamjimpat in forum Archive posts
    Last Post: 10-03-2007, 02:38 AM
