Thread: central locking only opens driver door none of the others
Results 1 to 10 of 15
  1. central locking only opens driver door none of the others
    Sep 2007
    Hello everyone,
    When i use the remote only opens the drivers door none of the other one's but when i lock it closes all of them.
    Another thing is the switch next to the driver seat on the door colum, what is it for?(Alarm?????)
  2. Smile Re: central locking only opens driver door none of the others
    May 2008
    Push the open button once and it only opens the drivers door. Push the open button twice quickly (like a double click on a mouse) and it opens all the doors and the boot, its a safety feature.
    The button on the drivers door column is to turn off the interior alarm sensor.
    Hope that helps.
  3. Re: central locking only opens driver door none of the others
    Sep 2007
    Quote Originally Posted by VWBora130 View Post
    Hope that helps.
    Thanks for the reply,
    I Know of the double click. It's not that. Any other advise?
    Cool alarm sensors switch, Thanks.
    And keep VWing.........
  4. Re: central locking only opens driver door none of the others
    134 Post(s)
    2020 Post(s)
    A fault code read.
  5. Re: central locking only opens driver door none of the others
    London
    The boot lock often 'sticks' and only opens after several clicks of the remote.
    The door locks may be doing the same.
    I see much better response after greasing them well.
  6. Re: central locking only opens driver door none of the others
    Mar 2007
    Nr chester
    if i click open once the drivers door unlocks, if i click 2 or 3 times all the doors unlock. i find the boot the worst.
  7. Re: central locking only opens driver door none of the others
    134 Post(s)
    2020 Post(s)
    I click for drivers and two clicks for all is correct for single door opening anti hijack setting.
  8. Re: central locking only opens driver door none of the others
    Sep 2007
    How do i remove the anti hijack setting?
  9. Re: central locking only opens driver door none of the others
    134 Post(s)
    2020 Post(s)
    It is done in the soft coding of the convenience unit using a registered version of VAG-COM or similar.
  10. Re: central locking only opens driver door none of the others
    Sep 2007
    It stopped working when the battery went extremely flat and i tried starting it. It was fine before that.(Listening to the radio while washing the car.)
  1. Replies: 8
    Last Post: 19-08-2009, 09:23 PM
  2. NSF door central locking
    By DerekSmallwood in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2008, 10:41 PM
  3. Door pressure linked to central locking?
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-03-2008, 05:27 PM
  4. Central door locking -- Doors won't open!!!
    By peegee in forum Touran - Sharan - Caravelle
    Last Post: 21-01-2007, 02:42 PM
  5. Central locking only works on passenger door
    By passatv5dub in forum Passat - Archive Topics
    Last Post: 12-06-2006, 02:21 PM
