Thread: EGR quickie.
  1. Question EGR quickie.
    Mike McKinstry Guest
    Guys,
    Pulled pipe off end of EGR valve ,engine off and cold and b/fly is open.
    Is this the correct position ?
    thanks,
    mike
  2. Re: EGR quickie.
    the Netherlands
    if you just want to test it use a hand vacuum pump to simulate operation. Open position should be normal as there is no vacuum applied the valve and with the motor off there are no exhaust gases to recirculate.
    cheers,
    Eric
  3. Re: EGR quickie.
    Jun 2006
    UK, Mids
    Is this the anti-shudder valve you are looking at?
    Audi A8 - 2015 - 3.0TDI
  4. Re: EGR quickie.
    the Netherlands
    Does the valve look like this one?
  5. Re: EGR quickie.
    No,looking into actual EGR valve-anti shudder is the black piece on side i believe?
    Mike
  1. just a quickie
    By Matt_MK3 in forum Chat - Anything with wheels
    Last Post: 21-03-2008, 12:17 AM
