Thread: Starting issue woes
  1. Starting issue woes
    Mar 2008
    Wonder if anyone can give me a clue on this. Car is a 1994 audi coupe 2.0 16v... Car does not start properly. Had new battery+ plugs fitted and it is still the same. The starter sounds ok to me, just does not start as it should. Sometimes you need to turn it for 5-10 seconds before it fires. Seems worse if left a few days. Hardish to start even if left overnight. Once started after being left overnight and ran for say 15 seconds then switched off ...and tried in say 2 minutes again it will start normally. When eventually started from cold it only idles at what it does when it is warmed up .. say 1000ish revs... not sure if it should or not. Any ideas appreciated ..
  2. Re: Starting issue woes
    May 2008
    Hey... I had a smilar problem like this with my 2.6E. Probably got something to do with your fuel. Fuel lines can get sticky. Try running some sort of additive though the petrol to clean it out. I ran some ingetor clearner though mine and that got rid of the problem. Also you might want to check your fuel pump.
  3. Re: Starting issue woes
    Mar 2008
    Thanks very much ! I will give that a try
  1. 1.9tdi 130bhp starting issue
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-03-2008, 05:14 PM
  2. A6 2.5 TDI SE (1995) Starting issue
    By M V E Pullen in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 07-01-2008, 04:34 PM
  3. Passat Syncro starting issue?
    By sampsan in forum Passat - Archive Topics
    Last Post: 18-11-2007, 10:14 AM
  4. Golf IV 1.8 starting issue
    By drevil in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-05-2007, 08:28 AM
  5. Golf GT TDI starting issue
    By help in forum Archive posts
    Last Post: 15-10-2006, 02:15 PM
