Thread: Wiring loom
  1. Wiring loom
    Jun 2006
    leeds
    Took my car t the main dealer last week. (2006 2.0 TDI SE) ENGINE LIGHT WAS ON. tHEY GAVE THE ECU A SOFTWARE UPDATE BUT SAID IF THE PROBLEM CONTINUES THEY WILL HAVE TO CANGE THE WIRING LOOM. GOT TO THE END OF THE ROAD AND LIGHT CAME BACK ON AGAIN. BOOKED CAR IN FOR A LOOM CHANGE UNDER WARRENTY. WHEN THEY STARTED THE JOB THEY NOTICED ACCIDENT REPAIR AND SAID WARRENTY NO LONGER VALID BECAUSE REPAIR WAS NOT DONE AT MAIN DEALER.
    QUESTION 1 IS THE WIRING LOOM ISSUE A COMMON FAULT.
    QUESTION 2 CAN THE MAIN DEALER DO THIS WHEN THE ACCIDENT HAS NO BEARING ON THE FAULT.
  2. Re: Wiring loom
    Hi The wiring loom is not a common issue unless damaged by water ingress.They can not refuse to replace the wiring loom unless the previous repairs can have caused any damage to the wiring.
  3. Re: Wiring loom
    what was the fault code?? They can refuse to do the work if the accident caused the fault or if the wiring has been repaired by a non-vw dealer as warranty will only cover for manufacture defect not accident damage defect but if they can see where the damage is on the loom they should be able to repair it.
  1. wiring loom question
    By Rob C in forum Golf MK3 - 1993 - 1999
    Last Post: 09-04-2008, 12:02 AM
  2. VW Wiring loom to radio
    By tubbs in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-03-2008, 01:00 AM
  3. Hi and wiring loom
    By montymole in forum New Member Introductions
    Last Post: 13-11-2007, 07:05 PM
  4. same wiring loom?
    By lee07 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-09-2007, 05:45 PM
  5. broken wiring loom?
    By Buckle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-03-2007, 10:09 AM
