Thread: Scratch removal/Paint touch up
Results 1 to 10 of 12
  1. Scratch removal/Paint touch up
    Angus, Scotland
    Hi guys/gals,
    Just wondering what the best thing to use on Phantom Black paint is to get rid of small scratches?
    A bit scared to just get the old T-Cut out and have a go as I'm never convinced it won't ruin the Pearlescent finish!!
    Any advice welcomed with open arms
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  2. Re: Scratch removal/Paint touch up
    Liverpool
    Hi Paul,
    http://www.detailingworld.co.uk/ is your new friend
    Gareth.
  3. Re: Scratch removal/Paint touch up
    Angus, Scotland
    Wow!!! My eyes are opened!!!
    I'm not as OCD as I thought I was
    How on earth am I going to split my time between Detailing World and VWAF?!?!?!?! ARghhhh.......
    Paul
  4. Re: Scratch removal/Paint touch up
    Mar 2008
    Farecla G3 for large scratches and G10 for fine scratches.
  5. Re: Scratch removal/Paint touch up
    Angus, Scotland
    Hey Shaziman,
    Cool, does these work well with the Pearlescent paint?
    I'm a bit worried that I'll ruin the finish on the paint!!
    Paul
  6. Re: Scratch removal/Paint touch up
    Bristol
    Hi, there are much better products available then the ones listed below so it depends on how deep the scratches are and how much you want to spend.
    Assuming its only on top of the clear coat they will be easy to remove by hand as its not actually touched the paint. Look at www.cleanyoucar.co.uk Can you feel them with your nails if you run your nail over the scratch?
    DO NOT use T Cut.
    Ensure that the area is very clean to begin with and all surface dirt has been removed, this ensure that you do not grind in any small particles into the paint and make it worse. Possibly clay the area
    Look at Meguairs Scratch X, Meguiars Bodyshop #9 Swirl Remover, Carlack 68 - Scratch Remover Paste and Chemical Guys - Scratch & Swirl Buff Polish
    http://www.cleanyourcar.co.uk/polish.../prod_147.html
    Ensure you buy some quality applicator pads and cloths.
    http://www.cleanyourcar.co.uk/access.../prod_124.html
    http://www.cleanyourcar.co.uk/microf...ths/cat_5.html
    Wax, depending on the type of finish you want, deep, wet, just plain shiney
    http://www.cleanyourcar.co.uk/wax/vi...ax/cat_60.html
    Ive used 3 of those products above on a 2006 A3 Maurtiuas Blue which I think is Pearl Paint. Ensure you cover with some good wax after wards and it will be as good as new.
    Yes Ive got OCD
    Aruba Blue B8 S Line 1.8T 160bhp,Piano Black Inlays, Black Stitching, 30mm S Line Drop
  7. Re: Scratch removal/Paint touch up
    Angus, Scotland
    Hey mkc.
    Fantastic site, think I'll be spending my lunch hour trawling through it
    Will probly go for the Megs stuff, as I can get that from the local shop rather than waiting for it through the post!! OCD and am impatient!!
    Paul
  8. Re: Scratch removal/Paint touch up
    Bristol
    Scratch X is probably your best bet from Halfords or MotoMan or something. I cannot stress how important a quality applicator pad and cloth is needed tho, you could end up making it worse. Good luck but Im sure you will be fine with scratch x and some patience if you do it by hand.
  9. Re: Scratch removal/Paint touch up
    Angus, Scotland
    Cheers mate,
    There's a Halfords just down from my work so i'll probably go have a nosey in there and see what there pads and cloths are like!
    will let you know how I get on!
    Paul
  10. Re: Scratch removal/Paint touch up
    Jul 2008
    Cheers mate i have the same issue with a little scratch on phantom black so will do the same!
  1. swirl mark and fine scratch removal
    By kronk10 in forum General Detailing/Cleaning Questions
    Last Post: 24-03-2008, 10:50 PM
  2. touch up paint
    By jimbouk in forum Chat - Anything with wheels
    Last Post: 27-02-2008, 01:17 PM
  3. Paint Stain Removal
    By Irri_Tant in forum General Detailing/Cleaning Questions
    Last Post: 01-11-2007, 07:24 PM
  4. Paint Stain Removal
    By Irri_Tant in forum Passat - Archive Topics
    Last Post: 01-11-2007, 11:36 AM
  5. Paint Scratch
    By andy2 in forum Audi A4 - Archive Topics
    Last Post: 19-02-2007, 07:20 PM
