Hi, I'm new to the forum and am hoping someone may be able to help with some info on brakes.
I've a R plate A6 2.4SE, and have just replaced all of the discs and pads after getting the brake wear warning indicator up. All went well with the fitting, but the brake pedal is now quite spongy. I assume that I need to do a fluid exchange, but have heard that this can only be done using special diagnostics kit, in order to open all of the master cylinder servo's/valves. Can anyone shed any light? Cheers
