Thread: A6 Central Locking
  1. A6 Central Locking
    lawsy Guest
    The central locking on my old A6 (1997) has packed in. I still here the central locking motor running when I use the key or lock but it doesn't open the doors. I presume the pump has packed in. Before I buy the part I wanted to know if it was accesible and if so where is it? I wanted to note the part number and also see if I could replace it myself.
    Thoughts?
    london/ UK
    Quote Originally Posted by lawsy View Post
    Thoughts?
    Hi, its under the rear seat bench if its a saloon next to the battery encased in black polistyren or in the boot if its an estate(avant)-check both sides. Also check the vacuum hoses for leaks first.
  3. Re: A6 Central Locking
    hi before u think of replacing locate the pump and pull out the inlet and out let air pipes sit inside and lock and un lock the car this will run the pump . place fingers over the out let and inlet one should blow out air while the other will suck in. if this is happening the there is a leak in the pipes locate the leak.
    if u r a handy man then look for an old unit open it up and remove the motor/pump assembly and fit it into u r unit. leaving the electronic control board . this will save u from reprogramming costs.
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. A4 Central locking
    By gre22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2008, 03:08 PM
  3. A6 central locking
    By dixielee in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-07-2007, 10:58 AM
  4. central locking
    By mwill82 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-01-2007, 07:57 PM
  5. a4 central locking
    By graham147 in forum Chat - Completely Off Topic
    Last Post: 30-07-2006, 04:52 PM
