Thread: Door Closed But Still Show Open
  1. Exclamation Door Closed But Still Show Open
    Mar 2008
    Cape Town South Africa
    Hi guys i need help really bad. I drive an Audi A3 1.8 2001 (proud owner). When i close my door the light in the car nor the two on the door goes out. When i remove the door panel it seems to work fine. Anyone had this problem before...................? Please guys help would be appreciated. Oh to ad to that, sometimes it works fine but as soon as it rains or they bang the door to hard it happens
    Patience is the ability to idle your motor when you feel like stripping your gears...
  2. Re: Door Closed But Still Show Open
    May 2008
    Quote Originally Posted by ydelong View Post
    Ialso have the same problem too REALLY WEIRD and as above when it rains but at the mo it is fine anybody got any ideas i heard it could be a sensor in the door lock assembly.....
  3. Re: Door Closed But Still Show Open
    May 2008
    Preston
    is it doing this just on the drivers door, or all doors?
    have you tried manually pressing the 'button' (or switch, whatever) inside the door jamb to see what happens?
    IF it is only happening on the drivers door, and no others. perhaps try swapping the button/switch for one from one of the other openings. if the problem has then been fixed, you needs to gets yourself to audi and order a new button.
  4. Re: Door Closed But Still Show Open
    May 2008
    seems to be a common fault as my brother had the same problem on his 1.8T and it has just started to happen on my 1.8T quattro..seems if i bang it shut really hard it goes away..but it might be a costly fix?
  5. Re: Door Closed But Still Show Open
    Had same prob on my 52 plate ,luckily Audi fixed under warranty, new lock fitted.
  6. Re: Door Closed But Still Show Open
    May 2008
    Aberdeen
    I've got an A3 1.8T Quattro 1999, and the same problem just started- hence i found this site.
    Had a look through other threads and basically it could be water getting into the wiring, or it could be that the door's sensor isn't making a conection to close the circuit.
    I had a look at the catch and gave it a wipe with fingers, checked it was moving back and forth correctly and it seemed to work again. Not sure if this was a coincidence or not.
    Also got a problem with the interior lights flashing sometimes when i'm driving. Is this related to above? Has anyone else had this?
  7. Re: Door Closed But Still Show Open
    Mar 2008
    Hi Guys thanks for all the replies, i found that the door switch is the problem but you have to replace the door lock in order for that to be fixed as they dont sell the switch lose. but the problem is that the price of the lock . the driver door half the price of the pas side door and it cost just under R800 here in South Africa and i dont need that one. the switch is sealed so no luck fixing it either.
    If any one know of a better option please do let us know.
  1. Interior lights will not turn off when door closed
    By hendy00 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-01-2016, 07:25 AM
  2. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  3. Sounds like my door hasn't closed properly at speed
    By metalmickey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2008, 10:20 PM
  4. Bootlid open message (even when it's closed)
    By MalcQV in forum Passat - Archive Topics
    Last Post: 21-03-2007, 02:33 PM
  5. Door open or closed?
    By kirley in forum Passat - Archive Topics
    Last Post: 22-04-2006, 04:15 PM
