Thread: Radio Interference
  1. Radio Interference
    Dec 2006
    warwickshire
    I have a 1998 'S' Reg TDI (110 BHP) sport passat saloon, with a issue with its radio. Its a factory fitted radio cassette Gamma radio, that up until two weeks ago worked fine, either on AM or FM. it switches on off plays cassettes not an issue, but know picking up a radio station is getting to become a right chore, let alone when you want to stay on say radio 1 or 2 (even with rds function on) it becomes a faded signal. the AM band you cant listen to it either with the engine off or on. with the engine off you can pick up radio 5, except theres alot of interference, when the engines running nothing. i`ve replaced the external aerial incase it was that, and this has not improved it at all. i thought these units lasted longer than the car! Any suggetions on what might be an issue?
    I am loathed to fitted an aftermarket cd player as my previous VW passat (1997, Tdi) had a sony cd player fitted from halfords, fitted by one of there technicians, and went back twice to correct the wiring, and to fit a signal booster. thus within two weeks of fitting it the wiring harness went up in smoke, thus having to replace the harness or scrapping the car, hence a new car, due to the new wiring harness alone costing 1000 english pounds.
    Oct 2005
    Lutterworth
    Quote Originally Posted by POSBORNE View Post
    Did you replace just the "stinger" bit ?
    The base of that aerial contains an amp powered from the radio by the coax.
    They have been known to fail.
    Straight forward to replace if you are brave enough to partly drop the headlining .
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Dec 2006
    warwickshire
    Thanks. In replacing the external aerial, it was purely the screw in external aerial but not the base unit. therefore the base unit might be of fault. thanks for the advice
  1. vag com and radio
    By new to vw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-05-2007, 04:30 PM
  2. Radio Sat Nav
    By Richardm in forum Passat - Archive Topics
    Last Post: 11-04-2007, 03:36 PM
  3. Radio only works with strong radio signals
    By RJS_90q in forum Audi A3 - Archive Topics
    Last Post: 25-02-2007, 07:47 PM
  4. radio interference
    By POSBORNE in forum Archive posts
    Last Post: 03-01-2007, 05:05 PM
  5. Getting TP off my radio !!!!!
    By simonr in forum Passat - Archive Topics
    Last Post: 09-10-2006, 06:42 PM
