Thread: Polo starting and PAS fault!!
  1. Polo starting and PAS fault!!
    Plymouth
    My customer has a problem we can't find!
    Car will not start sometimes. Powersteering warning light comes on and she looses powersteering.
    I have driven 130 miles (yes 130m!) in the car no problem. Mechanic has driven 15 miles of short journeys no problem!
    Fault codes.... according to our local diagnostic point none!
    So we have pulled all electrical connections apart to ensure dry and clean.
    Starting problem appears OK, but phone call to say PAS light back on. Turn car off turn back on, all is OK.
    I sell mainly German and Japanese to reduce the problems, hence this is driving me (and more importantly my customer) nuts!
    HEEEEEELLLLLLPPPPPPPPP.
    Martin
    If only I knew it before I bought it!
  2. Re: Polo starting and PAS fault!!
    Plymouth
    Update
    The car is a 51 plate (newer shape) 1.4 16v.
    The customer has had a re-accurence of the no start problem and the PAS problem. Apparently the starting problem occures when on a hill. Logic says fuel draining back. Anybody else had the problem?
  3. Re: Polo starting and PAS fault!!
    Plymouth
    Ok I am getting somewhere now.
    I have had the PAS light come on whilst driving it. The only change is that the low speed PAS level does not come into play ie at parking speed the steering is heavy. Now I guess this means a sensor fault somewhere.
    So tomorrow morning the car is booked in for a diagnostic check ( at our preferred independant). Fingers crossed we can nail this.
  4. Re: Polo starting and PAS fault!!
    Plymouth
    Ahh the fault code shows the position sensor at the base of the steering column as faulty. So time to order an exchange unit from VW.
    No faults shown on the starting front though.
    Apparently the starting fault occurs when the car is parked on an incline.... any ideas?
  5. Re: Polo starting and PAS fault!!
    is the owner a woman? my girlfriend had a nasty habit of flooding my old mk4 somehow, then it wouldnt start properly. other than that i'm baffled, weak fuel pump maybe?
  6. Re: Polo starting and PAS fault!!
    Feb 2013
    cwmbran
    hi all new to this site but i also have the same problem just as your about to park my polo 52 1.2 12v the steering goes dead and all the light are flickering and can hear the power steering pump buzzing on and off erratic ive checked voltage on battery and altonator but still doing it its fine when driving its just slow revs trying to park or something like that any help would be great
  7. Re: Polo starting and PAS fault!!
    Mar 2008
    Leiderdorp, Netherlands
    For the starting problem I would definitely do a thorough check on the fuel pump.
  1. Starting Fault
    By RSJMK316V in forum New Member Introductions
    Last Post: 23-04-2008, 11:11 PM
  2. V6 4motion Hot Starting Fault.
    By Fourmotion84 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-04-2008, 07:46 PM
  3. passat hot starting fault result at last
    By billza1967 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2008, 09:05 PM
  4. passat weird starting fault
    Last Post: 12-02-2008, 09:21 PM
  5. A6 estate starting fault
    By cliff in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-04-2007, 03:23 PM
