Thread: limp mode help passat b5
Results 1 to 10 of 12
  1. limp mode help passat b5
    hi i have a passat tdi auto 130 sport on 01 plate with 100,000 with history.which i have owned for nearly 3 years me and wife love the car but lately it has started to go in limp mode while going up hill or putting the foot down butif u turn car off and restart its ok the wife says its getting worse it also has a oil leek which seems to spray on to the plastic engine cover and comes out the front i had it to the local garage and he could not find the leek could enybody please help i live in northumberland advise which would be a good garage or enyone with avag com iam willing pay to have problem sorted thanks
  2. Re: limp mode help passat b5
    borasport Guest
    Boost presure control difference, caused by sticking vaines inside the VNT turbo, recycling the ignition resets this but the ecu will record the fault code, get this code then google it and it should say the same thing i have.
    Turbo replacement or recon.
  3. Re: limp mode help passat b5
    Emily's dad Guest
    I had a similar problem with my Alhambra. Turned out to be a faulty N75 valve which helps control the pressure in the turbo, the turbo itself was not at fault. Although mine was done under warranty it is actually a cheap fix, the part itself less than £50.
  4. Re: limp mode help passat b5
    cheers borasport hope u get this this site is driving me mad i wish i could use it propley
  5. Re: limp mode help passat b5
    thanks emilys dad hope so
  6. Re: limp mode help passat b5
    borasport Guest
    Hi, i was told N75 valve by vw but it wasnt, they can run a test for the cost of half an hours labour, but make sure they do the test in the gears and rev range that it happens to you as the test has set parrameters of 1500-3000 rpm in 3rd gear, which if your car was the same as mine was not enough to load the turbo up, they re ran the test in 5th and hey presto turbo failure. VW will recomend you donot have the turbo recond as do Garrret ( dont know about the KKK on the 130) but i had mine done and have had 20K miles of happey motoring.
  7. Re: limp mode help passat b5
    hi every 1 had car at local garage dignostic check came back 2 faults.first ecu part blocked intermitent .2 fault charge pressure control intermitent.bloke says computer cleared both faults. car is driving great feels faster and smoother is it possible 2 fix just like that .garage forgot to write code down when first put on computer cleared it took it for a drive put it back on computer which read all faults cleared thanks
  8. Re: limp mode help passat b5
    borasport Guest
    Thats a new one too me, although the second one you quote sounds just like what i had, keep us posted for a while and let us know how shes runnin
  9. Re: limp mode help passat b5
    May 2008
    This sounds like exactly the same problem I am having. I have a 2000 PD Passat - just coming up to 199,000 miles and was running perfectly until the last couple of weeks. Did you find that turning the ignition on and off (not the most sensible thing to do at 80mph), once cured it for the rest of the journey or did you have to keep doing it. I find that at about 80mph in 5th gear it hits a brick wall and i have to turn off and then on again. It cures it briefly but then it happens again. Its a bit embarrassing when it does it overtaking going up hill.
    Has yours remained trouble free since you had the faults cleared.
    I am looking to get mine checked in the next week or so.
    Rich
  10. Re: limp mode help passat b5
    borasport Guest
    Allright groomoid, your symptoms are normally the turbo, but as proved above can sometimes be different.
  1. ARL limp mode
    By Karlos_Fandango in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2008, 11:30 PM
  2. Is this limp mode??
    By fasttdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2008, 03:37 AM
  3. passat epc warning light and limp mode
    By thebear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2007, 11:51 PM
  4. Passat Turbocharger limp mode issue.
    By jase105 in forum Archive posts
    Last Post: 31-07-2007, 08:42 PM
  5. Passat TDI limp mode
    By ianocal in forum Passat - Archive Topics
    Last Post: 22-04-2007, 12:24 PM
