Thread: subwoofer upgrade in a4..
  1. subwoofer upgrade in a4..
    Hi guys
    I have an audi b6 avant (2002). I have a concert system with the standard 8 inch subwoofer in the side panel of the boot, along with the amp.
    If I was to replace the standard 8 inch subwoofer with this higher wattage woofer -
    http://cgi.ebay.co.uk/NEW-LEGACY-8-8...QQcmdZViewItem
    for more bass and less distortion at high volumes...would I need a higher wattage amplifier? I really just want to keep it all hidden away in the side panel of the boot.
    Would the new sub run using less power or would it simply drain the amp of all power it needs?
    Jonny
  2. Re: subwoofer upgrade in a4..
    Kent
    Hi Mate
    You wont really see any gain from adding a more powerful woofer as you will still only be putting the same power into it as you are into the Audi one - it would be best to upgrade the amp as well.
    You will probably find that running that sub on the standard amp will cause distortion as the new woofer needs more power to drive it properly
    Hope this helps a bit
  3. Re: subwoofer upgrade in a4..
    Yeh I thought that would be the case...oh well cheers anyway mate!
  4. Re: subwoofer upgrade in a4..
    Dec 2009
    cheshire
    anyone have the pinout diagram for the bose sub plug?
  1. adding a new subwoofer?
    By brianthornton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-01-2009, 08:32 AM
  2. Stereo - Subwoofer
    By james_tiger_woo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-08-2008, 08:44 AM
  3. A3 boot subwoofer
    By navnayyar in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-03-2008, 03:51 PM
  4. B5.5 Subwoofer Wiring Route
    By RobBentley in forum Passat - Archive Topics
    Last Post: 25-09-2007, 08:50 PM
  5. Subwoofer Wiring diagrams
    By gordymccrae in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-07-2007, 09:38 PM
