Thread: WINDOW
  1. WINDOW
    Nov 2006
    CHESHIRE
    HELLO ALL I HAVE JUST REMOVED A DOOR CARD ON MY PASSAT TDI (51 PLATE) TO SORT OUT WINDOW PROBS,AND AM NOW FACED WITH A METAL PLATE COVERING ALL THE WINDING GEAR,IS THERE ANYTHING I NEED TO DO BEFORE UNBOLTING THIS PANEL , I'M JUST DREADING THE GLASS FALLING , IS THIS LIKELY ANY ADVICE WELCOME REGARDS GAZ.
    scotland
    39 Post(s)
    There are two access holes at the top of the metal panel this lets you in to un clamp the window,it will need raised or lowered slightly so you can see the bolts,once you have done this you can secure the window with a wedge of cardbord between the glass and door.once you have done this you can remove the metal panel (window regulator)these can be found on ebay for a starting price of £19.99 + postage,hope this helps Calum
  3. WINDOW.
    Nov 2006
    CHESHIRE
    CHEERS MATE THATS PUT MY MIND AT REST,THANKS FOR THE INFO.REGARDS GAZ.
    be carefull as after removing around 10 x 10mm bolts there is the door lock mechanism and a tiny cable.to remove all this:
    1: remove black plastic plugs and wind window down till nut head is visible
    2: evenly remove both left and right side nut(get helper to hold glass
    3: this panel is sealed on and requires nudging and a semisharp blade to break seal
    4: loosen all 10 nuts and lift then tilt and lower steel frame out gently but remember to remove motor connector plug first
    5: your old motor can be removed and kept for a rainy day and the broken mech and plate scrapped
    6: lubricate the new cable runners to prevent another break
  5. WINDOW
    Nov 2006
    CHESHIRE
    CHEERS MATE THANKS FOR ALL THE DETAIL,HOPE I CAN HELP YOU SOME TIME REGARDS GAZ.
  1. Electric Window
    By LLX in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2007, 11:49 PM
  2. Window Tinting
    By benGT in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 21-02-2007, 05:23 PM
  3. Window sensor
    By grahamben98 in forum Audi A3 - Archive Topics
    Last Post: 28-01-2007, 12:44 PM
  4. ROPEY WINDOW.
    By GARY in forum New Member Introductions
    Last Post: 07-01-2007, 09:30 PM
  5. Window ECU
    By NickHuge in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-12-2006, 02:23 PM
